Question about Panasonic NN-S252WF Microwave Oven
Someone gave me a NN-S252WF Serial #6U82280086 under cabinet microwave. They said it would work, but cut off and the light didn't work. They took it to a service tech and he said they had a defective control panel/board and could not find the part. He tried putting in a new sensor, but that did not fix the problem. My questions is, does the part still exist and if so where might I find it. Also do you thnk it is too expensive to fix? Thanks!
    Habit-Forming:
  • 51 Answers
Panasonic changed their part distribution a few years ago and mesed everything up there new pqarts distributer in a company called Encompass. they dont typicaly dont stock a whole lot.
A lot has been discontinued.
Encompass
https://encompass.com/
Posted on Aug 16, 2017
3 Suggested Answers
EwingElect
  • 276 Answers
SOURCE: our microwave oven Panasonic NN-S252WF stops after
Our technician suggest that there may be a problem with the Inverter Board in this model, which is something that would need to be looked at by a Service Center.
In rare cases it could be the door switches.
Posted on Mar 27, 2009
heatman101
  • 43501 Answers
SOURCE: My Panasonic Model NN-S252WF is
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 25, 2011
Where is the fuse on Panasonic NN-S252
You may have to remove the cover on the microwave to find a fuse. It may not be either in a fuse holder or soldered into a the circuit board. be sure it is not plug up when you check.
if you find it be sure and replace with the fuse with same current rating.
Aug 01, 2014 | Panasonic NN-S252WF Microwave Oven
MY MICROWAVE WAS HIT BY A POWER SURGE. CAN IT BE FIXED?
always... but is a WalMart model cheaper than the repair.
Oct 19, 2013 | Panasonic NN-S252WF Microwave Oven
My microwave is now running at half power, even though the power level shows 10 on the display. I have to double the time to cook everything. I tried cutting the power to the m/w, and then turning it back...
Load test.
A simple safety test.
Place 1/2 litre of water in a glass container. Measure the temperature of the water.
Place in microwave and heat on full power for 1minute.
Measure the temperature after it has stood for 1minute.
If the temperature difference is more than 9 degrees Celcuis the magnetron is working and producing about 700Watts of heat.
If your microwave is labelled with 900 or 1000Watts. That is about right.
If the temperature is less then the magnetron is not working properly and may need replacing.
This a only a rough guide and any doubts you should consult an authorised service agent.
Mar 20, 2011 | Panasonic NN-S252WF Microwave Oven
My Panasonic Model NN-S252WF is not heating properly, it takes about 2x as long as normal to heat something
heatman101
Dec 15, 2010 | Panasonic NN-S252WF Microwave Oven
My model nn-p295wf microwave stopped working ,all power just stopped, about a year ago. I took it to a repair shop and they replaced the DIODE and the fuse, then it worked again. Afew weeks ago it happened...
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
Nov 16, 2010 | Panasonic NN-P295SF Microwave Oven
My model is nn-s253wf, micowave stopped working, no power, checked circuit breaker, is ok ?, unplugged, then plugged back in, still no power ?
Inside the external case and usually to the right left ( from Front) in some models There is a 30 amp fuse ( This may vatry on oven output amperage) Replace that and you should be back in cook mode.
Removing the case you should remember to disconnect from the power plug.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Panasonic NN-S252WF Microwave Oven
Microwave only runs for about 3 seconds.After
Chances are you have a failing magnetron.
But to allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "Microwave only runs for about 3 seconds then stops and the timer goes back to the clock mode.After several attempts then it will work.Problem is intermitten"
Dec 04, 2009 | Panasonic NN-S252WF Microwave Oven
Our microwave oven Panasonic NN-S252WF stops after
Mar 27, 2009 | Panasonic NN-S252WF Microwave Oven
Wiring Diagram for Microwave Door Switches
It took me a while, but I was finally able to get the FULL service manual that covers these models:
NN-S252BF
NN-S252WF
NN-S262BF
NN-S262SF
NN-S262WF
The wiring of the door interlock switches is shown on page 10.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Jan 15, 2009 | Panasonic Microwave Ovens
Panasonic NN-S252WF Microwave Oven Logo
49 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
