Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
Disconnect water from refrigerator never shut of switch for ice maker but still had power on for five days will it damage ice maker
    President:
  • KitchenAid Master
  • 2,651 Answers
No the icemaker will try to fill with water, none given not a problem. other then occasional listen to water valve activating with out water, yo should be fine, i wouldnt worry
Posted on Oct 09, 2010
Ice billed up in and around ice dispencer even when ice maker is off.
You don't mention a brand or model. All ice makers and chilled water dispensers must have a household water supply. This is controlled by water valves (much like a washing machine) that turns the water flow on and off as needed. If you've cleaned out the ice maker compartment, cleared away all ice build up and the icing problem recurs (usually over a period of days) then the water valve is leaking which lets water dribble into the ice maker compartment forming the ice. You can prove this by shutting off the water supply to the refrigerator (or even disconnecting it.) A new water valve should solve the problem.
Nov 01, 2016 | Refrigerators
Water and ice dispenser does not work---the switch clicks when you press it but there is not response, also the ice maker just quit working
Three things could be wrong:
Solenoid switch where the water comes into the unit has gone, this control the flow of water into both the ice maker and the water dispenser.
If the switch is good and then you need to check your filters, sometimes inside the door top right. or on one of the corners on the bottom front.. You should be able to unscrew them with you hands.. make sure water is off behind unit or where ever your shut off is at.
One last thing.. check for kinks in the water line behind the unit if it was pulled out lately.
Aug 10, 2015 | LG LFX25960ST Stainless Steel French Door...
Power surge caused appliance to go out. refrigerator ice maker now not making ice. has water on but no ice help
Reset the ice maker:
Locate the switch next to the water filter status light.
Press the light switch five times in 10 seconds or less.
Wait for the status light to change from red to green.
Mar 02, 2015 | Whirlpool Refrigerators
Icemaker will not shut off
The ice maker has a pin plug in the back of most model refrigerators. Disconnect there if nothing works to turn it off. What is the model number of your refrigerator? Does the ice maker have a shut off arm that turns the ice maker off, switch or does your model refrigerator have an electronic eye that turns the ice maker off? Let me know what you find, Thanks Sea Breeze
Nov 15, 2012 | GALAXY Microsystems 25.4 cu. ft....
How do i unhook or turn off water to ice machine?
There should be an on off switch on the right side of the freezer wall you can turn power off that will not allow water to the ice maker.
To disconnect water to the entire refrigerator there should be a shut off valve behind the refrigerator or under the kitchen sink usually.
Apr 18, 2010 | KitchenAid KSRG22FKSS Side by Side...
My subzero 650 ice maker drips water w/o making ice. Makes a mess with ice build up. I had to turn off water lined to stop the ice maker from dripping. Turning off the ice maker switch did not stop the ice...
Good day,
No, a new water valve should solve that problem. The diaphram in the valve is not completely closing.
Very common problem.
Thank you for using FixYa
Dec 24, 2009 | Sub-Zero 650 / O Bottom Freezer...
KENMORE ICE MAKER DOESN'T WORK. WORKED WHEN IT WAS NEW. NO WATER.NO PUMPING NOISE.
Good day,
The first step is to check the ice maker.
Pour water in the cavity of the ice maker until near full. Turn ice maker on and close freezer door and wait 2 hours. If it dumps ice then you can exclude the ice maker. If no action, and the water is still frozen in the cavity the ice maker must be replaced.
If the ice dumps then follow these steps.....
You want to check the water supply line to the machine from the house supply.
I prefer to shut the whole house down with the shut off valve at the meter. Disconnect the water line to the water valve at the bottom rear of the fridge. Point the open end of the water line into a bucket, and while watching have someone turn the water to the house on for a 10 to 15 second count. Water should come out of the line forcefully. If not replace the line and it's connecting valve.
If water supply is good, then replacing the water valve itself should solve your problem.
P.S. In rare occasions, the file tube from the back of the refrigerator to the inlet of the rear of the ice maker can build up with ice. You have to remove the ice maker to check this. If there is ice in this tube you have to melt it out.
However, caution using heat, as from a hair dryer ect. Heat from these devices can do a lot of damage to the hose and other plastic components in that area.
Nov 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No water flow to ice maker
Two possible answers on this one. The water control valve for the ice maker is defective or the switches inside the front of ice maker are stuck.
Please send the model number listed for your refrigerator so I can help you find the ice maker switches and parts break down for your refrigerator. Below is my website address.
http://servicepartstec.blogspot.com/
Let me know if I can help you more, Thanks Sea Breeze
Mar 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not working, water not going in tray.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Water dispenser spontaneously erupts when making ice
I had to fix a problem like this the other day you need a inlet solenoid
Aug 29, 2007 | Frigidaire FRS26KR4A Side by Side...
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
48 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
