Question about Garden
When I took the arm assembly (part #131845} off my 42" Craftsman mower deck the spring (part #140086) flew off and I cannot figure out how it is suppose to mount to the arm from the diagram in my manual. Help!
5 Suggested Answers
  • 5 Answers
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Posted on Apr 25, 2009
  • 246 Answers
SOURCE: Dont know where to hook springs to brake on mower
Hello Again verlam810:
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left. Select the "Mower Deck" Sub File.
>>There are 2 Brackets (#142) that the Springs #147 (Brake Springs) Attach to.
>>We can Use the Breakdown for a Reference if you have More Questions.
>>Till Next Time. May All Your Mechanical Problems be SMALL ONES and as Always, May the All Mighty Bless You and Yours. Be Safe and Happy.
Best Wishes and Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
  • 376 Answers
SOURCE: Where does the manual clutch cable mower deck
It should connect on top of the idler pulley on the idler arm. The bolt is extended and the spring hooks over it with a 'hairpin' or cotter key through the hole in the end to hold it on.
Posted on Oct 09, 2009
The GR8 1
  • 7 Answers
SOURCE: Craftsman 42 inch deck mower.
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Posted on Aug 13, 2010
I have a Toro model number 20622 auto start go forward and backward the blade won't turn it's like it's got a break on it how do I get this to work when I pulled the lever nothing happens
Anon, a lot of these Toro decks do have a type of brake on one of the idler arm and pulley to stop blade. You will have to get a repair/service manual if your owners manual does not show it. Normally can be seen in deck belt installation diagram. If blade brake checks out OK, it is possible one or both blade spindles bearings are seizing.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Lawn Mower Spindle Assembly Replacement Craftsman Lawn Mower Repair...
How to Replace Brake Pads on Mower Cutting Deck
Mower Deck Return Spring Replacement Craftsman Riding Lawn Mower Repair...
Apr 18, 2016 | Toro Garden
Model 917.20381 riding mower. Why don't blades disengage?
Terry, Deck full of debris around belt tensioner not allowing it to release, tension arm seized/spring broke, wrong/small belt installed.
CRAFTSMAN 42 MOWER REPAIR
My mower deck will not disengage
Blade will not disengage Craftsman 917 270662
https://answers.yahoo.com/question/index?qid=20090407155731AACRvsq
Sears Craftsman 917 272481 LTX1000 Riding Mower Deck Belt Blade...
Apr 08, 2016 | Craftsman Garden
Replacing a mower brake tension spring
Mower Brake Return Spring Replacement - Craftsman ...
? 2:15
www.youtube.com/watch?v=kyuE5NBR5xU
Jul 31, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step instructions for replacing abrake return spring on Craftsman riding lawn ...
Oct 27, 2015 | Craftsman Garden
Refer to brake pad arm assembly :I don't understand what keeps the brake pads from always riding on the idler pulleys. the springs keep them against the pulleys.
Hi, the spring on the brake rod pulls the lever forward when the brake is applied and a short lighter gauge spring pulls the lever back. This spring may be missing. Regards Phil.
Aug 22, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Replacing belt on lt1000 lawn tractor looking to fing where to hook spring to engage belt it popped off and cannot figure where wher to reattch it . is there a diagram on the layout Thank...
I do not have a diagram,but I do know where it goes.Look at the tension pulley.The arm it is mounted on move.That arm is where the spring belongs.First move the arm with your hand.pull it so that the blades are not engaged.Now the side of the arm away from the pulley and closest to the rear of the mower,is where the spring goes.There may be several holes,do not pull the spring too much,just get it in one of those holes.Then try the blades.If they do not engage,move the spring,to another hole.
May 20, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 inch deck mower. Model 917.277611 (2007). LT1000. 16.5hp Briggs & Stratton. Springs on cutter deck assembly broke. Had to re-assemble cutter deck. Re-attached springs and tension arms....
Aug 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
There is a big, wrap-around lifting bar in the front of my Husky used to raise the engine assembly off the mowing deck but I can't figure out how to free the engine assembly so I can pivot it up to expose...
most rideons have the deck assembly able to be removed without too much work.usually release any spring tension,then spring clips holding the arms on,then usually you can disconnect the belts and slide the whole deck out sideways,from under the rider.
Jun 29, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Problem Engaging / Disengaging the Blades
Two separate issues:
For free wheeling blades, it is time to replace the following items:
Brake Arm Pad Assembly # 131845X900 (Item 53 in picture)
and depending on condition:
Torsion Brake Spring(s) # 140086 (#58 in picture)
Take a look at Idler Pulley # 131494 (#36 in pictur, checking for wear. Sand and other abrasives will eventually wear the pulley down.
For engagement of handle: Lubricate all moving parts associated with the handle. Use only a dry film moly lubricant. Do NOT use WD40 as it is a penetrating oil and offers very little lubricating properties. Do not use oil as it will only attract dirt and eventually clog everything up.
The idler pulley previously described is on an articulating arm that must move freely, otherwise it will be (1) hard to engage and (2) cause slack when disengaged. In addition, this will result in premature belt failure.
FYI, although a Craftsman badge, this is an AYP (American Yard Product) tractor with a Murray Deck. Keep this in mind when ordering parts so you don't pay for "name branding".
Please let me know if I may assist further.
Best regards.
May 06, 2010 | Garden
Where does the manual clutch cable mower deck spring connect to on a Craftsman YS4500?
Oct 09, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
