Question about Bosch 24 in. SHU43 Built-in Dishwasher
Completed solder proceedue about 2 months ago. worked ok till now. Now same symptom has occured. no heated water, long wash cycle. Maybe the board or attached relay are done?
  • John Gullo Jan 06, 2011
    Great thanks, did you replace the relay as part of a new board or did you replace the relay on the original board. My d/w is 8 years old but the circuit board assy. is only about 3.5 years old as I have replaced once already. Really a weak point for Bosch. Any ideas on where I can purchase a greater amp relay. If I decide to repalce the c/b do they come with the higher relay?
    Thanks,
    jlgx4
  • John Gullo Jan 09, 2011
    Great, thanks. I'll give it a try before I spend another 200.00 for a control assy.
    jlgx4
  • Bosch Master
  • 2,605 Answers
Hello
Welcome to FixYa.
Based on your post, the solder may not have been sufficient to hold, or as you alluded to, the relay itself has failed now.
The best thing to do at this point may be to remove the control, clean up the point of soldering really well and retry thr repair to see what results.
If this is indeed the SHU43 series dishwasher, there are two different diagnostics possible, one of them is presented at this link from my profile...
http://www.fixya.com/support/t6347232-shu_4322_dishwasher_fills_water
...you`d have to provide the complete model number to identify which one applies to your machine.
The other opton I`ll leave with you is the possibility I can email a guide which includes the tests and other service tips.
Contact me at macmarkus@live.ca if interested and provide your FixYa username so I can identify who you are.
I`ll watch for your reply, good luck.
Regards,
Macmarkus :)
Posted on Oct 10, 2010
  • txxttxxt Jan 05, 2011
    I had the same problem - solder procedure worked for few months and stopped... After checking/testing it, I decided to replace relay and so far so good. Looks like the root of the problem is that relay in use is rated at 10A while heating unit uses around 11A. Even though 10% of deviation is usually ok, some number of relays will burn out. If you looking to replace relay go with the one that has higher rating, I used 12A one.
    Cheers,
    TxxT
Cheers, TxxT
Posted on Jan 06, 2011
  • txxttxxt Jan 07, 2011
    I replaced relay on the original board. For SHU43C02UC/22 the original relay was 899-1c-f-c 6VDC. I replaced it with Tyco T7CS5D-06. NTE's R46-5D12-6 should work too. Tyco's relay is taller than original and I had to cut a hole in a plastic cover for it.
    I bought relay at Digi-Key (www.digikey.com). For under $5 delivered worth trying :-)
    Cheers,
    TxxT
Bosch she56c02uc dishwasher does not cycle, stuck on wash
If the display is stuck on 2H it often means the heater is not working. If the water is not heated, the cycle will never complete. It is possible the heating element is bad, but a more likely problem is with the control module PC board. The solution requires some basic repair and soldering skills plus the tools to do the job. Bosch recommends re-soldering the connection to the heating element relay (see page 11 of "SHU/SHI/SHV Dishwasher Troubleshooting Tips") free download here The problem is that the circuit board copper is not heavy enough to handle the heating element current, causing the copper to heat and melt the solder connection. A better solution is to solder a short length of copper wire between the two pins to provide more copper and reduce the chance of heating as shown in the attached photo.
Nov 11, 2013 | Bosch 24 in. SHE56C05UC Stainless Steel...
Upper tray does not wash clean, bottom does
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
May 10, 2010 | Kenmore 24 in. 15782 / 15784 / 15789...
665.15824000 dishwasher
What is your water temp. This model has 4 automatic water heat cycles built in to it and it heats the water to 145 degrees and won't let advance till that temp. If the water coming in is lower than 120 degrees it will add about 2 hours to your normal wash cycle.
Feb 12, 2010 | Dishwashers
There is a terrible odor coming from washing machine
Make sure there are no leaks from the machine. Look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose is completely clear of debris and soap scum build up and check that the filter is clean.
To keep the machine clean of waste build up and to keep any bad odours away
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
As you have replaced the interlock switch check that it is working my using a multimeter on it.
If that is Ok then you probably have a problem with the wiring from the switch to the controller board or with the controller board itself.
Oct 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and
REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added
together, (e.g./ “6” = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil,
measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays
at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
testing will end shortly after water has started circulating
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Maytag washing machine skips rinse cycle
I found this problem with mine intermittently and it was because i had filled the machine too full that it was too heavy to initiate the spin. maybe try a lighter wash?
Jul 03, 2009 | Maytag Washing Machines
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
Intermittent problem, unable to select normal wash cycle/start
restart curcuit board sequence
push start hold down air dry and start until lights blink and machine starts then it should work normal
most dishwashers have an instruction booklet behind the botton panel that is nearest the floor you wll have to remove the panel it has a couple of screws. the booklet should be there unless installer took it.
If you omly replaced the front panel board then you may have to replace the circuit board inside the door. It works like a mother board in a computer. Good luck
Nov 17, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Hotpoint Dishwasher
have you tried adjusting the feet on the front of the washer so it is tilted back slightly .This will stop the water from coming over the little lip on the front of the machine. Some dishwashers also use a little amount of water in the bottom when drying asthis helps to curculate the heat ; leave the washer to complete it's cycle and it should beep to let you know when it is finished
Dec 09, 2007 | Dishwashers
Bosch 24 in. SHU43 Built-in Dishwasher Logo
530 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
