I WAS GIVEN A SECOND HAND EMACHINES KEYBOARD AND MOUSE
WHEN I SET IT UP TO RUN NOTHING HAPPENS AM I DOING
SOMTHING WRONG
    Problem Solver:
  • 6 Answers
I have had this problem before. sometimes you can do nothing wrong and the machinery will simply refuse to work together nomatter what you do. never blame yourself unless you know for sure you are wrong. always suspect the machinery first. first step is to re-trace your steps VERY very carefully. double check every step you take until you are absolutely sure you have everything correct. sometimes the simplest mistake can cost you dearly. check all of the connectors to ensure no damage has occured to the pins and then re-insert them with the machinery turned OFF. when you have done all of that, then switch on and listen for any warning bleeps, if none occur, then you have devices that will work together, but maybe not just yet. if they still do not work, then re-set the machinery, and try to find new drivers for them on the internet here, maybe the just need an update. it would help if you could tell us what system you are using, what o/s (windows, linux, etc), as much as you can fathom out. try what ive said, first then see how you go. let me know either way, please. bye, teknomancer.
Posted on Jun 08, 2008
How do i fix logitech mouse
No lights of any kind? First, make sure the battery is put in correctly. It is easy to get them backwards and absolutely nothing will happen. I had a logitech mouse given to me as nonworking and all I had to do was turn the battery around and it worked fine. Second, you might need to try a different brand battery. I have had AA batteries that had short terminals on the + side and would not make contact in the battery box of the mouse. If neither of those work clean the terminals in the battery box really well with a fingernail file or knife or even a fingernail emery board. Sometimes a little corrosion can be in just the wrong place and keep the battery from making contact. If none of these work the mouse has more serious problems than you probably want to tackle, given the price of a new mouse.
Sep 15, 2014 | Logitech Cordless Mouse
The mouse button doesnt always work
Hi!
There is a problem on your clicker and maybe your mouse had work for a long time. It calls for replacement.
Jan 22, 2014 | Samsung R719 keyboard - R719 laptop...
Keyboard and mouse not working
is your mouse and keyboard wireless?
If so your connection may not be set up right.
If your keyboard and mouse are wired with USB port plugs then you could have either a faulty cord or USB ports in your system. Try using the keyboards on another PC and see what happens. Also you cannot connect a keyboard and mouse after the system has booted into windows and expect it to work. Either way your system will think nothing is attached until you reboot. Try this out and see what happens.
May 06, 2010 | Microsoft Windows XP Home Edition
Cpu turns on but nothing else does.
Well, when my emachine did this, I was informed the "power toggle" was "gone" and that basically it would cost more to fix than to replace. I suggest you have this looked at as I suspect you will be given similar information.
Wish I had better news. Good Luck!
Feb 19, 2009 | E-Machines eMachines Desktop PC
After installing hard drive, monitor, keyboard, mouse not working
Have you tried to enter BIOS? Are you able to enter BIOS?? There may be an option you have to hit to enable SATA, and to select the boot device order, which may be messing things up.
Also, remember that STATIC ELECTRICITY is your enemy! Ground yourself when working inside the case.
Dec 30, 2008 | E-Machines eMachines Desktop PC
I just bought aused computor with a mi wireless keyboard and mouse. The keyboard works fine but do I need somthing for the mouse to work?
you probably have a reset button on transmitter and posibly on bottom of mouse make sure you reset them
restart pc and if it still does'nt work I would run software again
Dec 07, 2008 | Micro Innovations PD7250LSR Wireless RF...
Snooze button on my acer keyboard
To disable the sleep button on the acer keyboard Do the following (Vista home)
Go to control panel (classic view) double click Power options.
left hand margin select Choose what the power buttons do.
This opens a systems settings page
You will see an option :
When I press the sleep button: (Don't worry that the picture of the button is different than the keyboard's Zz)
Select Do Nothing from the dropdown box.
Click the Save changes button at the bottom of the screen.
This will disable the button on the keyboard...
May 28, 2008 | Acer NSK8458AN Keyboard
Flashing power button - no keyboard nor mouse. But PC works... ??
Yes, it may be that the +5v supply from the PSU is faulty, as the PS/2 ports run on 5v and USB runs on 9-12v. Replace the PSU with another of the same form factor and same power rating or better (>=230W). They come at ~£30, so not too expensive. For a little more. Try this:
http://www.quietpc.com/gb-en-gbp/products/psus-300-500/x-red-psus
Jan 28, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
292 people viewed this question
David Payne
David Payne
