Question about Oreck Vacuums
Oreck vacuum is smoking and the roller is not turning. vacuum is turning on and inflating well.
    Brigadier General:
  • 4,088 Answers
Remove the roller assembly and clean/oil (3-1 oil or similar) the end bearings which are usually jammed with string, thread, and hair. Check the belt for burning or other damage, assemble the belt over the roller and motor shaft, then install the roller into the base making sure to twist the belt if required. Look for a guide diagram cast into the base. Hope this helps!
Posted on Oct 09, 2010
  • 58 Answers
Sounds like the roller is jammed up. The motor keeps driving the belt, but for some reason the belt cant drive the roller. The smoke is coming from the belt, Clean the junk out from the roller.
Replaced belt but still smell smoke odor
Hello, this is Leland with Crucial Vacuum,
If you are smelling a smoke order one of two things may be wrong with your unit:
Firstly, the motor may be the problem. If you hear any noises while the machine is running, you should contact the original manufacturer for trouble shootingsolutions.
Secondly, your vacuum may be in need of new parts. By changing either the brushroll or belts, you should be able to increase the quality of the suction, and eliminate any smoke odors. Since you have already replaced the belts, I have copied a link to the compatible roller brush that we carry for your unit!
You can purchase replacement parts for your Oreck unit direct from Crucial Vacuum with freeshipping and an exclusive 10%coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/oreck-xl-roller.html
Mar 09, 2016 | Oreck XL Deluxe U3700 Bagged Upright...
I changed the roller brush on my Oreck XL Insight vacuum and now when I turn it on it only runs for about 5 seconds and shuts down Any ideas
Bigme03,
It sounds like you may have been given the wrong brush roller. Several models of Oreck's have a sensor in them that watches for the brush roller turning at the proper speed. The way they do this is by mounting a magnet into the brush roller and the sensor counts the number of times the magnet passes. If that magnet is not there or if the sensor does not detect the magnet passing, ie..a broken belt, it will shut the motor off. The only way you can fix it is to get the correct brush roller and put it back in. Hope this helps!
Mar 07, 2015 | Oreck XL Insight Upright Vacuum
I have an Oreck Commercial XL upright vacuum. While I was vacuuming under the bed, I picked up something that must be stuck behind the roller. Not sure how to get the cover off the vacuum to look into...
First thing to check it to confirm that you have a clog. flatten out the bag and turn the vacuum on. if the bag inflates then you dont have a clog. if the bag doesnt inflate then you do have a clog. to remove the clog turn the vacuum upside down you will notice 5 Philips screws that are sunk in the baseplate. if you remove all 5 screws the baseplate can come off just by pulling up once you take it off you will notice a few things. i first suggest removing the belt by rolling it off the roller brush or motor. after the belt is removed you can now take off the roller brush by pulling up on it. now you will be able to look in to the intake pivot which it the peice that is left of the motor that the air flows through. I would look in there if you see something then pull it out if not then there is a step you can take further. remove the 2 motor screws but dont take out the motor. and remove the screw in the intake pivot. now you should be able to pull up on the intake pivot and it will come off. now you can look into the fan from where you just removed the intake pivot. if you see something there then great if not then I would start re-assembly once you have everything back together, turn the vacuum upright and so your facing the black metal tube. unscrew the lower black collar to the left. and then disconnect the outer bag from the metal clip an that same location. then pull staight up on the black tube and that will seperate from the base so you can look in the fanhouing and the tube it self. after clearing it put it back together tighten the collar and clip you outer bag in and your all set!
Sep 19, 2011 | Oreck XL2600 Vacuum
I have an Oreck Halo that is not picking any dirt or dust up. Any suggestions?
It may have a clog in the unit. if you unzip the outer bag, the hard shell bag, the bag on the inside should inflate instantly as soon as you turn the vacuum on. if it doesnt then it has a clog. Halo's are on of the hardest vacuums to work on. they take a lot of time and is almost impossible to explain how to fix it. i would definitely recommend bringing it to an authorized Oreck dealer to fix it if it is not a clog.
also make sure your roller brush is spinning when your on your carpets. if it is not spinning then i would try the reset button while the vacuum is on which is on the right side of the back of the vacuum is a little red button on top. you cant miss it.
Aug 24, 2011 | Halo UVST Bagged Upright Vacuum
Eureka upright is smoking and blowing air rather than suction
Yes the first thing that I would do is to change the belt...run it for a few seconds and then check the belt... if it is hot then you have found your problem...if it is cool then you need to keep looking...
heatman101
Apr 28, 2010 | Oreck XL Ultra Bagged Upright Vacuum
My oreck vacuum has stopped sucking up things.
It won't turn the brush because the belt is stretched or broke from the heat of sucking something too big up. If you have your service manual it should show you the location of the belt covers to replace it.
Dec 03, 2009 | Montgomery Ward Oreck XL Celoc...
My Oreck XL was working fine, then when I vacuumed a shag rug is started smoking and smelled like something is burning. (I changed the bag, checked for clogs--none found, and roller brush is turning. It...
Even though the brush is spinning, the belt is probably worn out and stretched. when you vacuum the shag carpet, it puts more drag on the brush. try running it on a shorter carpet or hard floor for a few minutes. if it doesn't smoke, then you know it's your belt. if it does smoke, then it's probably the motor burning up.
Jim
Jun 02, 2009 | Oreck XL2000 Bagged Upright Vacuum
I Need a Wire Diagram for my Oreck XL3600HH!!!
I emailed that diagram to you, hope it helps.
Apr 14, 2008 | Vacuums
Oreck Vacuum troubleshooting
Hi. If the motor is on its way out the motor noise will be eratic eg slowing down speeding up popping noise & a smell of electrical burning. If you have none of these symptoms then chances are its not the motor. Does the bag inflate or is it easy to collapse when you push the bag ? If bag inflates ok check belt. If bag not fully inflating check for blockages along length of the handle pipe its designed to pull apart by lifting up rubber sleeve at machine end of pipe, push ball latch in & pull pipe out remove any debris stuck in the pipe. Remove bbottom of machine as if replacing belt check to see if there is any debris stuck in the oppening that goes to motor fan, then check the fan blades you can see them through the port is there any missing or snapped off. If blades are missing or have big chunks missing you will need to replace. If fan only has minor bits missing then reassemble it should now worl well.
Sep 07, 2007 | Vacuums
Vacuums Logo
276 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
