Question about Toshiba Satellite 1805-S253 Notebook
I have a Toshiba satellite A200 - 1CJ, old of almost 1 year. It doesn't want to start AT ALL. After I plug it in, the battery's led looks red and the power led BLINKS blue. Have you any idea what happened?
  • Marius Ceh Oct 12, 2010
    Well, it seems that it works only on battery, if I'm recharging it at another Toshiba laptop. It means that the motherboard is OK, but the power circuit on it is broken. As far as I know, it has those very small SMD safety devices (not "traditional" ones), not easy to be replaced without specialized equipment. Possibly, the primary power microchip is fried, also... Thanks for the advice; it is, in deed, a problem on the motherboard... Lucky me it isn't fried completely...
    Master:
  • 397 Answers
It sounds as though your system is getting no power at all- try a second ac adapter. If that does not work, if in warranty, contact your technical support provider to get it serviced. If not, there is a good chance you will need a replacement motherboard- find a reputable technician and see about purchasing the replacement board.
Posted on Oct 09, 2010
Testimonial: "Thankz!"
    It works on battery, if I recharge it on another computer. Probably the power circuit is fried. As far as I know, it has those very small SMD safeties (not traditional ones) that can be replaced only with specialized equipment. Thanks for the solution, it is, in deed, a problem on the motherboard. Lucky me it isn't fried completely...
My Notebook all of sudden doesn't power on.
I find that many times when a laptop won't power on either on batty or plugged in, the thing to try is to unplug it, then taske the battery out for about a minute and then put the battery back in and try again.
Dec 13, 2012 | Toshiba Satellite L755-s5248 15.6" Laptop...
Have a toshiba satellite a305-s6853 and it wont power up is thier an internal fuse
Remove your battery plug in your a/c power - you should get a power led light on your unit - if not power led try your power pack on someone elses toshiba or try there power pack on yours - if a good power pack starts your unit then refitted the battery whilst its running and left it charge - that means you have a dead power supply - if it doesn't respond with and alternative power pack your d/c input cct has failed. new m/board.
Jul 10, 2011 | Computers & Internet
My daughters Toshiba satellite l505d will not boot up correctly. It starts but then nothing happens. What do I need to do. Have already taken battery out and restarted. Any help would be helpful.
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
If yes - Battery is defective
If no - Motherboard Problem/AC adapter
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. Reformat your computer and install necessary drivers and applications
Thanks. Cheers!
Apr 15, 2010 | Toshiba Satellite L505-S5966 Notebook
I have a Toshiba L300. The battery doesnt charge. When plugged in, no power is coming into the unit so cannot use.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Nov 13, 2009 | Toshiba Satellite Pro L300 Notebook
One battery doesn't charge...the other doesn't discharge
The new battery is defected, you have to replace the battery.
Aug 31, 2009 | Computers & Internet
For laptop: Toshiba Satellite A105: My battery won't charge/computer won't turn on when plugged in. No lights show when plugged in. Don't know if it's a problem with the chord or the computer. Don't want...
Start by trying another power outlet.
The power adapter should have its own light. If it doesn't light up then the adaper is bad. Kensington.com sells very inexpensive universal power adapters. You might also find a good deal on eBay.
If the adapter lights up then it may be your battery. Notebook batteries are only good for 2-3 years. If you let them sit for a long time without a charge they may only last 1-2 years.
Vote for this solution if it helps.
Aug 18, 2009 | Toshiba Satellite A105 Notebook
Toshiba satellite m55-s135 won't power on even when plugged in
When the AC adapter is plugged to the wall, if it has an LED make sure it is on, remove the battery and connect the adapter to the laptop, does it power up?
Install the battery after charging, see if your laptop powers up.
If the laptop does not power up, the motherboard needs replacing.
I hope this helps to resolve your issue.
Good Luck.
Mar 15, 2009 | Toshiba Satellite M55-S135 Notebook
Battery charging problem for toshiba satellite p30-145
After 4 or 5 years, the battery will be too dead or old to take a charge. It needs to be replaced.
Feb 17, 2009 | Toshiba Satellite A105 Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
Toshiba Satellite 1805-S253 Notebook Logo
165 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
