Question about GE PTS22LBN Top Freezer Refrigerator
No cooling or freezing bbut fan seems to be running
  • 58 Answers
Check underneath coils to see if they are covered in dirt and or lint. this will impede heat dissipation. BE CAREFUL
Posted on Oct 09, 2010
Wine fridge is always running but never cools below room temperature.
the processor cooling fans for the CPU and case fans are 3 PINS.. you can use them but remember that these are 12V fans. once its the same power it will work. Ps if needed you can cut the connects from your old fan and connect it to the new ones to get it to fit properly..
Dec 30, 2012 | Haier HVTS18DBVS 18 Bottle Dual Zone Wine...
Computer freezes / locks up after running a while,
Sounds like it's overheating. Check to make sure your graphics card cooling fan and CPU cooling fan are working. If they are add some case fans. Get a can of compressed air and clean out all the vents and fans. You can also use a vacuum with a hose attachment to clean it.
Jul 21, 2012 | Acer Computers & Internet
Fridge is not cooling/freezing properly. have tried to clean vents and coil(floor level) by removing grill and using vacuum wand also cleaned some vent in rear. model #TFX24CR. It is still keeping...
One additional thing to check is behind that rear vent behind that cardboard covering for the compressor. See if the fan motor next to the compressor is clean and the fan seems to running at a high speed. If that fan motor is running but doesnt seem to running as fast as say a table top fan would be running,go ahead and replace that fan motor.
Gene
Aug 15, 2011 | GE Refrigerators
How so get the fan uptop in the freezer compartment to work, seems the fridge is working, the compressor turn on and the everything freezes and the lower section of the fridge does not cool.
You will need to unplug the wire connector to the fan motor and check for power, you should have 120 volts when the fan is in running mode. To get it running mode turn the cool to the coolest setting when opening the freezer door tape or hold the door switch closed fso the fan will try to come on. If the fan has power but does not come on replace the fan motor.Here is a link that should help http://appliancehelponline.com/refertopevapfan.html
Sep 10, 2010 | Frigidaire FRT21H8 Top Freezer...
Thinkpad 2373: boot and freeze problems.
raodonald
If you are having trouble with your fan running it is possible that the notebook is over heating.
Think about when it ran good and when it did not. Was the fan running and/or was it cooler at that time. Also if you are in a place where it is cool outside you might take the system outside in the cool to see if this makes a difference.
If is does work more when it is colder then most likely the fan is not cooling the system properly.
Let me know if you have any more problems or questions
Issken
Jan 18, 2010 | IBM ThinkPad T40 2373 Notebook
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Gateway laptop 450ROG freezes up after it gets hot & screen frzs
This definitely sounds like a heat problem. The system fan should cool it, but there may be a lot of dirt in the heat sink or along the path that the fan blows air. The first thing I would try is to get a can of canned air and blow it into all the vents under and on the side of the computer. If it is dusty, keep your face away.
You didn't say, but if you let the system cool down for a while (maybe 15 minutes or so) and start it up again and the same thing happens, it['s definitely a heat issue.
Feb 08, 2009 | Gateway 450ROG Notebook
GE PTS22LBN Top Freezer Refrigerator Logo
60 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
