Question about Refrigerators
I have a frigidaire model frs26lf8cw1. i had to replace the dispehenser board now when i plug the board in the ice maker will not stop dispensing ice, not sure what to do?
  • 58 Answers
My kenmore started dispensing ice and water for no reason. After unplugging, I removed the cover from ice/water dispenser and discovered a burnt circuit board. Leave the board unplugged until you can obtain a good circuit board.
Posted on Oct 09, 2010
  • jusomedewd1 Nov 09, 2010
    I had water flooding out the dispense board and found the circuit board soon shorted.
    I think, during testing the power board has 120vac coming into it....its supposed to reduce it to 5vdc, but what I found was 120Vac everywhere.
    So I think the 120 was getting to the water inlet valves and they were open all the time.
    Also the ice maker does not use the dispense board. My dispense board is totally out of commission adn the ice maker works on its own. it makes ice and the arm should turn it off.
    it won't dispense ice nor have the ager turning without the front dispenser working...but you will get a full bucket of ice!
    after seeing all the problems and issues with water and ice dispensers I'm about ready to leave mine off.....
Frigidaire refrigeratyor ice maker doesn't get watyer
either your filter was put on in the wrong direction or when u replaced there were stuff in the line and it stopped up the hose or your have a crimp in the line
Dec 23, 2015 | Frigidaire FFHS2611LB Side By Side...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Frigidaire ice maker not working
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | Frigidaire FRS6R5EMB Side by Side...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice Maker Dispenser Motor Won't Stop Running
There is a plastic part in the dispenser that holds the micro switch that operates the auger motor when you push the paddle. If you're handy with hand tools, you can order the part and replace it yourself. The part is on the outside of the door.
Jun 15, 2017 | Kenmore Refrigerators
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Water dispenser spontaneously erupts when making ice
I had to fix a problem like this the other day you need a inlet solenoid
Aug 29, 2007 | Frigidaire FRS26KR4A Side by Side...
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
