Konica Minolta Printer Error as follows: misfeed detected-remove misfeed at circle
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
osiriscompu
  • 16 Answers
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Posted on Jul 19, 2008
  • 52 Answers
SOURCE: "Can't Detect Genuine Toner Cartridge"
minolta printers work on "chips" if the chip atached to the cartridge is not original minolta you better change it.
Posted on Jun 18, 2009
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
How removed misfeed indicated problem?
a miss feed mean the roller could not get the paper, so clean the roller (s) or have them replaced, try a different paper draw
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 25, 2014 | Konica Minolta Di2010 Di2510 Di3010 Di3510...
Konica C550 Misfeed error how to get rid of it?
I know this sounds silly but some try flipping the paper over, then try turning it 180 degrees. Printer paper has a grain (a direction that allows it to feed through the printer better).
Mar 27, 2014 | Konica Minolta bizhub Office Equipment &...
Misfeed detected. Remove paper indicated by 0
misfeed is different then a jam. jam is the paper hit something miss feed the paper rollers can not pick up the paper. clean the rollers or replace them and or there associated clutches
Feb 21, 2014 | Konica Minolta Bizhub C451...
Oki b6250 misfeed paper
oki B6250 printer,what is the misfeed error and then shows paperjam
Nov 11, 2013 | Konica Minolta Minolta Di351 DiAlta...
Paper misfeed
828120c7-b2c6-4ef1-86da-8d12eb17847a.jpgkonica minolta c451 printing this type
Jun 03, 2013 | Konica Minolta Bizhub C451...
Bizhub C35 misfeed error
This video will show some of the most common causes for Bizhub C35 misfeeds
https://www.youtube.com/watch?v=Sbo0gon8EIY
I’m happy to help further over the phone at https://www.6ya.com/expert/mark_3d8ef710fe85c567
Feb 26, 2012 | Konica Minolta bizhub C351 All-In-One...
Misfeed detected but no paper jam
Di 251 is legacy Minolta machine, Minolta is now Konica Minolta
for the image unit try this site
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
as for the adf replace!!! the rollers all three try the same site above
Nov 03, 2009 | Minolta Di251 All-In-One Printer
Model cf3102 display misfeed detected
We get a miss feed on our when we load too much paper. Try loading a little less. To undo a miss feed from overloading it you have to open and close all the drawers and eventually it will go away.
Jan 29, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Misfeed and PDF failure
Thewre could be even a small piece of paper stuck. Try looking even closer, and even open a close the access lids to reset the triggered switch. Even a minute pice of paper in the wrong location can cause a sensor to be triggered and until it is reset it will not work.
Mar 31, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
442 people viewed this question
k24674
jasbo
jasbo
