Question about Frigidaire Affinity ATF7000E Front Load Washer
What is the code E10 mean? My washing machine starts washing and then a message pops up saying E10, what does this mean? I can't even run a spin cycle. Please Help, Kristina
    President:
  • Frigidaire Master
  • 2,651 Answers
Looks to be a long fill error. check to make sure your water supply is turned on, and any water coming through the hoses.
Posted on Oct 09, 2010
My washer keeps popping up with EFO in the display window.? What does this mean and how do I fix it/
E10 error is water inlet hose clogged. Screens should be cleaned out. Hot and cold. If you can't do it yourself get someone to help you.
Good luck.
Feb 21, 2015 | Frigidaire Affinity ATF6000F Front Load...
I have a frigidaire gallery series front loader washing machine and when I am washing it says e10 what does e10 mean
it means you have a problem with the water supply. start by takeing off the hoses and cleaning the inlet screens on the washer with old tooth brush. I have to do this about every two or three months on mine because of it getting clogged.
Mar 24, 2014 | Washing Machines
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
What does the code E10 mean? The washer flashes that code and won't spin.This is and Affinity front load washer.
When error code E10 appears just take the cold water off the inlet tube to the washing machine, then clean the screen using light force air then replace the hose .Finally turn the water back on.This should solve the problem. If not the door latch needs adjusting or tightening up. It's probably something really simple like a loose screw.
Thank you !!
Jun 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have an frigidaire front load Mod.# GLTF2940ESO with an recurring E10 error message. HELP!!
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Apr 11, 2010 | Frigidaire GLTF2940ES Front Load Washer
Wash starts, then stops postin E10 and now soap does not dispense
Aug 02, 2009 | Frigidaire GLTF2940F Front Load Washer
Front Load washer with error code E10, stops before spin
10E on electrolux means water hasnt emptied before max empting time,(drain problem)it wont spin because of this,this could be the same situation even though its a frigidaire
May 07, 2009 | Frigidaire Washing Machines
Zanussi washing machine won't start E10, E40 & E50 at times
It was suggested that the pump had failed and taken out the programmer with it - expensive! Wife wouldn't wait, and bought new machine. Problem almost solved - anyone want an out of order washing machine?
Feb 03, 2009 | Zanussi ZWF1440 Front Load Washer
Frigidaire Affinity Front load washer, Starts to Fill, then Flashes E10, Was wondering what this code is referring to
May 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Error messages EFO and E10
It is simple. The wrong soap or too much soap will caused EFO to flash. I overfilled the machine with soap by accident. It started flashing with EFO and I went nuts. What could be wrong with it now?! Too much soap or not the right kind of soap will cause this problem.
Plus, I found a sheet of paper that gives the codes.
This is better than when the strainer plug gets filled up and you have to take the machine apart to clean the little strainer.
Apr 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
538 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
