Question about Dell 1600n All-In-One Laser Printer
Driver for printer Dell 1600n for macO/S - Dell 1600n All-In-One Laser Printer
  • 50 Answers
Www.dell.com/support/downloads make sure u select the right operating sytem pulldown choice
Posted on Oct 10, 2010
Have got new pc driver for Dell 1600n needs to be installed
Here is the link from Dell Official Support for Drivers download for Dell 1600n
Select Operating System and get the drivers and software.
Good Luck!
Appreciate generously if the solution could have been of any help!
CreativeTECH
Dec 16, 2010 | Dell 1600n All-In-One Laser Printer
Unable to locate disk to install our Dell Laser MFB 1600n printer after CPU had to reinstall windows and now the printer is not working.
You do not say which version of Windows, so I am providing a link to the Dell Driver page for that model:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=PRN_LSR_1600N&os=WW1&osl=en&catid=&impid=
Feb 23, 2010 | Dell 1600n All-In-One Laser Printer
Dell 1600n. I have to reset the printer constantly.
Do a hard reset of printer to erase all memories. Then also uninstall and reinstall the driver and see what happens. Also make sure that you are using the correct driver for your OS
Sep 12, 2017 | Dell 1600n All-In-One Laser Printer
Dell 1600n to be used on an imac
Hello! Unfortunately, Dell printers mainly supply Windows drivers on their website. To print to this printer, your new iMac will probably pull a generic driver to use with the printer. It should still work no problem, as you're saying, however you won't be able to use the software that's available on the PC. The downloads available for your Dell printer are here:
Dell 1600n Printer Downloads
You can tell by clicking that link and looking under Operating System that only Windows operating systems are available, as well as the software shown below, which is only made for Windows based systems. As for the PaperPort software, that program is made by a company called Nuance. When you purchased your printer, you most likely received a trial or full OEM version from Dell along with your new printer as a software bundle deal. From what I can see, the software is only Windows based. Sorry!
Below is the link to a free viewer that can still read your PaperPort files:
PaperPort Viewer for PC and Mac OS [Free]
Mar 16, 2009 | Dell 1600n All-In-One Laser Printer
1600n Printing an Extra Page everytime...
I had a computer experiencing the same problem.
I found under the printer properties that there was 2 drivers listed; both say "Dell Laser MFP 1600n PCL 6"
I swtiched the settings from one to the other.
The Printing Preferences also show more options.
  • Open the Printer(Control Panel->Printers>Dell MFP 1600n)
  • On the menu at the top click Printer->Properties
  • Click the tab at the top Labeled Advanced
  • Change the driver and Click Apply
This should fix your problem.
Nov 08, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n printer driver for Windows 2003 Server
I had a similar problem deploying these printers, however i found using the XP drivers in 2003 does work fine. Not sure why dell doesnt have an installer for this printer in 2003 server, but here you go.
ftp://ftp.us.dell.com/printer/R165289.EXE
extract that file, note its destination directory. do not attempt to run the setup.exe, it will fail saying your operating system is not supported.
instead navigate to (if you didnt change the path) C:DelldriversR165289p0nPrinterPCLWINXP
this folder contains the driver you need to install manually.
one stange thing about these lexmark based network printers is the need to select 'local printer' during install, uncheck automatically search for my device, and then create a new TCP/IP port. Use the IP address provided by the network configuration print out you can access on the front panel of the printer. now just make sure to select 'lexmark network card' as the type of network interface. it should now ask you for your printer type, click have disk, and point to the driver folder mentioned earlier.
hope this helps. thanks alot dell.
Oct 30, 2008 | Dell 1600n All-In-One Laser Printer
Have a Gateway laptop with Windows XP. Want to use Dell 1600n printer
Download the drive from Dell, and run it to unzip it. When adding the printer, click "Have Disk" and point it to the folder that you downloaded the driver to.
Jun 19, 2008 | Dell 1600n All-In-One Laser Printer
Driver for mac OS for Dell 1600n
If you install the Xerox1600n it should work for you. That is what we had to do.
Feb 24, 2008 | Dell 1600n All-In-One Laser Printer
Windows Vista can't find networkd Dell 1600n
Make sure you're using the drivers for Vista, which can be found on support.dell.com. You'll want to use the choice for Vista 32-bit.
Also, try turning off your firewall, as it may be blocking the network data.
Dec 15, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
61 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
