Question about GE Televison & Video
GE D52gw12 Green light comes on and off 3 times then tv shut self off. No picture or sound comes on nothing, sometimes I hear a high pitched squeal.
  • jkman4 May 30, 2008
    OK thanks, I can't find a schamtic for tv and not sure were the transistor is, can you point me in the right direction? Also is there a web sit I can get the part at?
  • jkman4 May 31, 2008
    Toshiba C5588 447
  • 4,234 Answers
The set is shutting down to prevent further damage. There is a problem with the high voltage circuit. The most common failure part is the horizontal output transistor. Figure on $20 or so for parts plus the local labor rate to get the total repair cost.
Posted on May 30, 2008
  • ABRsvcs May 30, 2008
    Look for a transistor mounted on a heatsink close to the flyback transformer. It is probably marked C5438 or something similar. Post the marking here and I'll give you the complete part number.
50 " DLP makes a high pitch squilling sound and shuts off several times
Check and replace its color wheel. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 10, 2014 | Samsung DLP HL-P5663W 56" TV
Try resoldering the flyback transformers connections on the board. Its very common for the flyback pins to develope cracks around the pins which can cause that issue. I would check that first with that model.
Jun 13, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
High pitch noise, no picture. GE 52" projection, Model D52GW12
Ur high voltage FBT the flyback tranformer,a big black block of plastic with a gray wire connected to a board.The cap it dead.The FBT it useally it dead too,arching noise FBT not holding the high voltage.
Mar 30, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
CTR Television will not power up
What has happened is that the horizontal output transistor has shorted. The squeal you hear is the power supply running under a heavy load. The picture narrowing or being distorted indicate that the horizontal output was not operating clean. Something in the output section was not as it should be. Possible short in the output transformer/tripler unit or something loading down the secondary voltages generated by the horizontal output. You will need a tech to figure this out....If you are not a tech, then this ones a goner as far as fix it at home goes.....If you are a tech I might be able to talk you through the repair. Have someone remove the horizontal output transistor and I bet the squeal goes away.
Feb 10, 2008 | Televison & Video
3 blinking lights and no picture
The whine or squealing you hear is either the color wheel or fan. To determine which, when the noise is heard from the set, turn it off and listen carefully. If squealing stops immediately then Tthe fault is the color wheel, not the fan. And sounds like that are generally the color wheel. A new color wheel is Samsung p/n# BP96-00250A for this model. Vance Baldwin carries them for $97.20 plus shipping. Logon as guest, select parts and copy past the above part number in without any dashes. Good luck... Bill
Jun 08, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
203 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
