Question about NetGear WGR614 Wireless Router
Unable to connect to netgear router - NetGear WGR614 Wireless Router
  • 2,263 Answers
Is it a wireless computer or the wired computer?
I believe the main computer is online.
Check the settings on the router.
You will need to open the router set up page.
here you will see the settings of the router.
If you are trying to connect to the wireless network then make sure that you are typing the correct network key.
Click here for more information about routers and network
Posted on Oct 09, 2010
How do you connect netgear extension to router
This article provides instructions on how to wirelessly connect to your NETGEAR Wi-Fi Extender using manual setup after the NETGEAR WiFi Extender has been successfully connected to the Access Point (AP) and obtained a valid IP address.
https://kb.netgear.com/25504/Unable-to-connect-my-NETGEAR-WiFi-Extender-using-manual-setup?cid=wmt_netgear_organic
Feb 23, 2017 | NetGear Computers & Internet
My netgear wpn824wireless router does not start up . the lights just stay on. what do i do ????
  • open Command Prompt, type 'ipconfig/all' and hit Enter. Check Default Gateway, it should be 192.168.1.1, your Netgear device's IP address.
  • If you are still unable to browse the Internet, ping your router's connection to the PC. Open Command Prompt, type 'ping 192.168.1.1', hit Enter. If your PC is receiving connection from your Netgear device, you will see a message like Reply from 192.168.1.1: bytes etc. If there is no connection, you may see the Request timed out message.
  • The Request timed out error can occur due to two things: (1). incorrect physical connection between your Netgear device and the PC or (2) incorrect wireless network setup & configuration. Recheck and correct the Ethernet connection between your PC and the Netgear device. Also reinstall the TCP/IP stack and update Netgear device driver software.
  • When done, check back if you can browse the Internet or not. If the problem persists, hard reset your Netgear wireless router
If you need any kind of technical assistance you can contact support cell at -http://vtechsquad.com/netgear-router-support/
Sep 02, 2012 | NetGear RangeMax WPN824 Router
Connected but unable to view website
You might need to check the security on your router , if its enable or not.
You can try the solution below to check your router wireless security. Note this should be done on a computer that is connecting to the internet thru the router.
1. open browser and enter http://routerlogin.com
2. username is admin , password is password.
3. click on wireless option .
4. look for the wireless security settings.
If you dont have another machine that is connecting to the internet. Just follow the steps below.
1. Reset your router for 30 seconds by holding the reset button.
2. turn off for 30 seconds after resetting it.
3.Power off the modem and turn it back on after 2mins.
4. If all the lights on the modem is stable power on the router, make sure the modem is connected to the internet port On the router.
5. check your computer which has a usb adapter,. Look for the wireless icon, You should be seing an option were in it will allow you to view the available wireless,
6. Look for the wireless name "netgear " and press connect. CHeck if you have internet.
Rate me if the solution is helpful
Kevin angell.
Jun 14, 2010 | NetGear WGR614 Wireless Router
Unable to log other computer on through netgeat
Is it a wireless computer?
If you are trying to connect to the wireless network then it is very simple.
Click Here for more Info
Oct 06, 2009 | NetGear WGR614 Wireless Router
Unable to factory reset - all port lights stay on with just power cable plugged in
All port lights showing on a router indicate a bad control board in the router. I'd say it's toast.
May 25, 2009 | NetGear WGR614 Wireless Router
Wireless internet connection
Fog will not affect radio signals. Please go to the following website and follow the instructions.
http://kbserver.netgear.com/kb_web_files/n101676.asp
Oct 30, 2008 | NetGear WGT624 Wireless Router
Netgear router
connect by Cat5 cable to router and use ip address of router, normaly 192.168.1.254, in you address bar in IE this will connect you to the router setup screen so if you go to the wireless set you will see the wep key
Apr 19, 2008 | NetGear DG834G Router
Plz solve
need more information - do you have cable? DSL? Are you able to connect when you put the Ethernet cable directly into your computer and bypass the wireless router? The wireless signal is only indicating that your router is "broadcasting," but does not mean you have a usable Internet connection.
Feb 17, 2008 | NetGear WGT624 Wireless Router
NetGear WGR614 Wireless Router Logo
23 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
