Question about Kenwood KAC9105D Car Amp
I have a Kenwood KAC-9105D amp. It is brand new and worked for about 20 minutes while I was driving and it hasn't worked since. When I turn my car on, the blue and red LEDs on the amp both come on for a split second and turn back off. I have checked the fuses, re-secured EVERY cable for the amp, checking all the connections. Any ideas? I'm at a loss as to why it isn't working.
    Problem Solver:
  • 9 Answers
First of all, how are your subs wired to the amp. Make sure your amp is not bridged or you'll fry it, it only has one channel. If that doesn't work you probably already fried your amp.
Posted on Oct 26, 2010
No sound from my subs
it should have a red light on if it is in protection mode. If it does not have the red light then buy a new amp and check all you wiring
Nov 22, 2013 | Kenwood KAC-9105D 1800W Max Class D 1 Ch...
Kenwood kac-9105D amp
Tipical for that amp.Did you buy it used?
Oct 27, 2012 | Kenwood KAC9105D Car Amp
How to bridge a kenwood kac-9105d
Are you referring to something like this, using two different amps? It is a mono amp, meaning there's one amp in the box.
"KAC-9105D also has a Dual Mono Drive connection that allows you to strap two KAC-9105D amps together to power a single subwoofer."Quoted fromhttp://www.kenwoodusa.com/Car_Entertainment/Amplifiers/KAC-9105D
Here's a link to a page out of the Yamaha Sound Reinforcement book. the top shows a stereo amp (1 box, two different amps inside) hooked up to drive two different speakers, which is known as 'stereo' mode.It then shows the two amps hooked to the opposite sides of the same speaker, which is known as 'bridge' mode.http://books57.net/ampOuts.gif
Any help?
Feb 24, 2012 | Kenwood Car Audio & Video
I have a Kenwood KAC-9105D amp with 2 Rockford fosgate 10 inch subs in a sealed box. When i turn the volume up loud the bass fades out for a few secs and then comes back to being loud again, this keeps...
It's the battery, not enough juice to supply your amp at loud volumes so the bass will drop out especially on long bass notes. Replace your battery!
Sep 25, 2010 | Kenwood KAC9105D Car Amp
I have a Kenwood KAC-9105D amp with 2 Kenwood KFC-W3012 subs in a seal box. When i turn the volume up loud the bass fades out for a few secs and then comes back to being loud again, this keeps happing over...
Cant solve the problem but can help calling kenwood in am i have to of those amps and both do same thing its a cooling problem only 1 little fan pulling air out going to buy couple bigger fans and install in both ports and will let u know how it works out
Aug 06, 2010 | Kenwood KAC9105D Car Amp
What is the p. con on the back of the kenwood 9105d?
Power control wire - tells the amp to turn on, usually connected to the blue/white or blue wire when blue/white is not present on aftermarket radios. On factory systems you usually want to hook up this connector to an acc source on the car
Jun 13, 2010 | Kenwood KAC-9152D Car Audio Amplifier
Amp turns off after about 5-10 minutes of use for a few seconds
One of two things...Amp is going into overload protection (should be indicated by a light on the amp), or you have insufficient power going to the amp....if this is the problem, try a 2 farad capacitor on the input power line to the amp.
Mar 12, 2009 | Kenwood KAC-8104D Car Audio Amplifier
How to wire kenwood amp to kicker cvr 12"
How you wire it depends on how hard you want drive your amp. If your woofer runs 4ohm per coil I would wile it in series (amp +to sub +1 sub -1to sub +2 amp - to sub -2) then run it for a week and see if it has enough power. the lower your Impedance (the resistance load on the amp) the harder your amp works and more THD (noise) is produced. (Dclass amps aren't know for being clean to begin with) configured like this your amp will see 8ohms and sound the clean east. if this turns out to be not enough power wire it in parallel and double the output. wire amp + to sub +1 and +2 then amp - to sub -1 and -2.
A word to the wise... start with your volume very low and work up slowly most speakers will puk up the voice coil before the amp starts to get warmed up. you would hate to have to buy a new sub.
Have fun
Rob
Dec 10, 2008 | Kicker CVR12 Car Subwoofer
Kenwood KAC9105D Car Amp Logo
396 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
