Question about Samsung LN-T4061F 40 in. LCD HDTV
I have a LN40b530p7fxza flat panel Samsung. It is a year and a half old...and just out of warranty...2 weeks ago it started going black for 4 to 5 seconds with no change in audio. Then the picture comes back for 1 to 2 seconds and then goes black for the 4 to 5 seconds. I am directly connected to cable (no box). I tried a direct connection to a DVD player...no change. Then tried a wii...no change. Even the on screen menu disappears.
  • bobbytaylor1 Dec 29, 2010
    januaryjtd - I am having THE EXACT ISSUE. I also timed it and its the exact timing also. Did you talk to Samsung? Were you able to have it repaired? If so share your results. If you would please go tohttp://forums.cnet.com/7723-13973_102-51... and post your experience. It would help the others having the same issue.
SOURCE: No Picture - Samsung LN-S4692D 46in HDTV LCD
I had the same problem and I replaced the t-con board. My t.v. is fixed!!!! I just couldn't see spending another 700.00 dollars for a repair shop to fix it. The t-con board is located at the top of the t.v. once you remove the back cover. Be very careful removing the two plugs at the top of the board which was easy once I figured out how the clips worked. there is a black lever like connection which flips up, then grip with your fingers the tab and slide the tape like wires straight out. The bottom plug is very simple. Also to expose the t-con board you will have to remove a heat shield cover. Once removed there is foil looking tape that needs to be peeled back to expose the board. The board is very sensitive to static electricity so if you have a grounding strap that you can strap to your wrist and ground to the frame while performing your repair. Its best to lay the t.v. face down on the kitchen table with a blanket to protect the screen. Good luck!
Posted on Sep 07, 2008
SOURCE: TV connections- Wii, Direct Tv and DVD palyer
Hidden switch for output coonections on back panel of dvd player.
Posted on Dec 29, 2008
SOURCE: Samsung Plasma 50" No Picture but have sound
BAD Y BOARD
Posted on Jun 08, 2009
SOURCE: Samsung LN-R408D - No Picture
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you: 0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid 2) know what you're doing with a soldering iron and teensie SMD parts 3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
Posted on Sep 22, 2009
SOURCE: Bottom half of the screen is black on Samsung HP-R5072 50 in. HDTV Plasma Television
I have a solution. My Samsung plasma had the same problem with the bottom half of the screen being black. Follow these directions and it will not cost you a dime, just some time. I took the back panel of the tv. I found the lower buffer board on the left hand side. I disconnect all the ribbon cables. Use an air cleaner to spray out any dust on the ribbon connection and the board. I connect the ribbons back to the board. My plasma is now as good as new. If you have issue with the top portion, do the same with the upper buffer board. I was going to buy a new tv but I'm glad I gave this a shot first. It's been almost a month and it's still working fine. Hope this helps and hope it saves you some money.
Posted on Nov 14, 2009
I bought a SyncMaster 2333 monitor 1 and half year ago. Suddenly, my monitor does not show anything. Turn on/off switch is not working. Sometimes it shows just bluescreen. I am wondering what is wrong and...
This problem usually indicates a failure of the power supply board that runs the video control board. You can fix it but if your unit is only 1.5 years old then its still under warranty, 3 years parts and labor. Go to www.samsung.com and go to the service section to start a warranty claim. It takes about 2 weeks to go out and back to you.
BuddyMc
Feb 27, 2011 | Samsung SyncMaster 2333SW 23" LCD Monitor
I have sound but no picture. 42" plasma. i bought 4 years ago. last week the botom half of the screen started flashing back and forth between the picture and all black, but we just came home and now it is...
Sounds like you need a lower Y-DRV/BUFFER board (996500032640) and a Y-SUS board (996500032643). Part numbers listed are for models which use a Samsung Panel.
May 10, 2010 | Philips 42PF9630A 42 in. Plasma Television
SAMSUNG LE40M86BD very thin black line
The screen is failing. A conductive strip from a flex connector to the glass panel is losing contact when cold. Any warranty left? extended warranty? Usually not repairable, screen has to be replaced and cost as much as a new set....
Mar 24, 2010 | Televison & Video
Panasonic plasma.only 18 months old and the screen seems to be filling in from the left inwards.totaly black and about 1 third of screen is gone completely now and getting worse.started about 2 weeks ago...
it is possible that either the d-board is going bad or 1 of the c-boards. try to find and authorized panasonic servicer to help with the repair. we are authorized and in dallas texas. our business is Aces Tv Service.
Nov 17, 2009 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
Slow startup clicking sound for about 45 sec
If it is less than a year old find a authorized repair center and have it fixed before the warranty runs out.
Aug 09, 2009 | Samsung LN-T4671F 46 in. LCD Television
1/2 the picture
Hello
You will have to a tec. for this one as you have lost half of your vertical sweep.
Sorry
guy9
Jun 16, 2008 | LG 42PX5D 42 in. Plasma HDTV
Samsung HP-R4252 42 in. HDTV screen black outs and red lines
Hi: We had this problem under warranty, and tech installed the following to solve it: Parts BN96-02033A, BN96-02034A and BN96-02216A. This solved the problem for 2 years. I now have the upper half going black now and then for 2 to 3 seconds. I am ordering these parts from www.partstore.com and will just plug them in. Better than a new tv.
May 25, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Screen went half black then full black
Sounds like a common voltage adjustment with samsung plasmas,I would call a service center these are things if you dont have experience you shouldnt attempt yourself
Apr 26, 2008 | Samsung HP-R4272 42 in. Plasma HDTV
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Dec 17, 2007 | Samsung LNT3242H Television
Samsung LN-T4061F 40 in. LCD HDTV Logo
163 people viewed this question
Jerry Greenberg
Jerry Greenberg
