I need to connect a Homeywell thermostat to a Carrier Weathermaker,Model 58SX060-CC-1.
  • 3 more comments
  • Jimmy Anderson Oct 09, 2010
    I tryed hooking it up the way you said and turn the CB on and the 3 amp fuse on the printed circuit board blew,and the fan are still running.
    My Carrier Weathermaker,Model#58S060-CC-1 blows fuses when I turn the heat on.Can you send a diagram on how the Tstat should be connected to the unit and the Heat Pump?
    There are no Model number on the Tstat but it is programable
    No the comment was they need to know the Tstat Model number.I dont have the number but it is a Honeywell programable model.
  • Jimmy Anderson Oct 10, 2010
    can not find the Model number of my Thermostat.
    It is a Honeywell Programable thermostat. It was around $110.00 from Home Depot
  • 15,935 Answers
What is the model # of the thermostat?
Thanks!!!!
Posted on Oct 09, 2010
  • 22,156 Answers
Just connect the thremostat in the power lead to the compressor motor ,thats all its so simple ,i bought a ex demo unit and the control panel with all the fancy remote and electrics not working but i didnt know so when i eventually installed it and found out that was all i done ,found the lead to the compressor joined the power in cable to the thermostat then on to the compressor and its been running two summers now with no problem
Carrier weathermaker I have model #48dp016520 I don't hear any blower heat coming in. What would be the problem
The thermostat may not be sending the heater control relays power. The heating element or the gas valve may not be functioning.
Jan 07, 2014 | Air Tools & Compressors
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a Carrier Weathermaker SX HVAC unit with a Honeywell thermostat. Even if the thermostat is turned "off", my fan keeps blowing!
Hello, usually this is a sign of a bad blower relay on the intergrated control board. The only option is to replace the control board.
May 09, 2012 | Heating & Cooling
Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know wbwill@sbcglobal.net
Oct 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace pilot is on, pilot ignitor continues to click, no main flame
sounds like the sensing bar on the spark ignition is dirty.....a wire brush works nicely.
Oct 17, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Weathermaker SX Carrier 58SX060-cc-1
Your blower motor may have failed. Check the blower motor for the air circulation and you may find it is hot but not running. Have the motor replaced if this is the case.
Jun 11, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker gas 8000 will not ignite
1. check indoor unit wiring.
2 check sensar of thermostate.
3if not change thermostate
Mar 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
