Question about Dryers
I have a whirlpool front load dryer. the dryer had been running fine when i start a new load and pressed the start button nothing happened
    President:
  • 1,554 Answers
The thermal fuse is blown. Disconnect power then locate the thermal fuse on the blower housing and bypass. Once located, join the wires together and insulate them properly. Reconnect power then start the dryer. The thermal fuse is indeed blown if the dryer starts and heats up. Replace the thermal fuse along the thermistor or cycling thermostat depending on the model of the dryer. Do not use the dryer with the thermal fuse bypassed due to fire hazards. Bypassing it is for troubleshooting purposes only.
The blower housing can be found at the rear of the dryer if the lint filter is located on top. It can be found at the front of the dryer behind the lint duct if the lint filter is located on the front.
Figure1: Dryer with filter on top.
Figure 2: Dryer with filter on the front.
Figure 3: Dryer with filter on the front (thermal fuse and thermistor).
Indicate the exact model number of the dryer should you need further help. You don't have to accept, reject, or rate this solution to add information or, post comments and follow-up questions. But accepting the solution will not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 09, 2010
Turn on power, the lights come on but when you press start nothing happens just a click sound.
Click sound at power button and start button should get it going. If not then Dryer drum is not turning.
Aug 08, 2013 | Whirlpool Cabrio WED5550XW 27" Front-Load...
Whirlpool front load dryer will not start
Does your dryer have a reset switch on the back, usually a small red button, if it does press this and ten test dryer starts again.
Dec 21, 2012 | Whirlpool Dryers
My whirlpool dryer wed9400sw2 is over a year old, but has stopped running. The last load was left damp. When I tried to restart the load, I pressed Power, Start. I hear a brief click from the start...
Hello Cdewlodge, we sincerely regret to hear this. If resetting the Dryer did not help then we would recommend scheduling service. If you would like for us to schedule service for you, please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
May 28, 2017 | Whirlpool GEW9250 Electric Dryer
I have had my whirlpool front loading dryer for about 5 years. It worked fine for a couple of loads and then when I started to dry the next load, it won't come on. It just beeps, checked the breaker,...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 02, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Push start button but nothing happens but buzzing noise
Is Kenmore a Whirlpool?
  • Here is what happened.
  • Stopped running mid-cycle.
  • Dryer set idle for about two hours Then I pushed start butten again.
  • It ran fine to finish load.
  • Next load it was totall dead and silent and remains that way.
  • The vent hose was unobstructed.
May 04, 2009 | Whirlpool Dryers
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool LER5644EQ2 Electric Dryer that won't start
HI yes it could be a fuse its called a thermal fuse located at back of dryer remove back on the left sede on air duct a fuse with 2 smaller blue wirse that should be your problem thanks THE APPLIANCE DOC
Sep 06, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
49 people viewed this question
Top Dryers Experts
