Question about Amana AGR5725SDS Gas Range
I pressed lock then cancel, how do i get it to unlock?
  • 58 Answers
Did you try to hold the button down for more than 5 seconds? or try to push both buttons at the same time for 5 sec?
Posted on Oct 09, 2010
  • jrlt51
    jrlt51 Mar 31, 2013
    Yes I did n it worked. Thanks.
I locked my phone and cant unlock it
most phones open with pressing unlock then space bar. If that doesnt work, look on the side of the phone and see if there is a lock button
May 07, 2012 | T-Mobile MDA
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
How do I unlock the child lock on my Panasonic Genius Microwave?
March 2009 press the function key,select option #5, select option#2. This should take it out of child lock. If this doesn't work enclose your model number and I will try to look up the manual
Or, press "Cancel" three times to clear the (child) lock.
You set the lock by pressing "Start" three times.
Apr 01, 2010 | Panasonic NN-T888S Convection/Microwave...
Forgot code to unlock channels. How to unlock?
After you set the lock, you will need the secret code in order to:
• view a locked program,
• view the locked TV, or
• cancel the lock.
If you forget the code, you can view the locked TV without entering the code. To do this, simply
press the buttons on your remote labeled "QV" and "9" at the same time whenever your secret
code is requested. Unlocking theTV this way is temporary.
To change or permanently cancel the lock:
I. Turn on your TV. If the TV requests your secret code, press
and_ at the same time.
MENU
2. Press _ to view the main menu.
3. Use the • o rV to select ..V..-Ch p Parent Lock and press ENTER .
4. The on-screen display will ask for your current passcode. Press
and _ at the same time.
5. The on-screen display will now ask you to enter a new code:
MENU HOME
• To cancel the passcode permanently, press _ or _ .
• To change to a new passcode, use the number buttons to enter a
new code, then press E_R,
IMPORTANT
You must use the remote control included with this
TV. You cannot use a remote control from another
Mitsubishi component and you cannot use "Univer_
sar' remotes from other manufacturers.
Oct 02, 2009 | Mitsubishi VS-55707 TV
Lg incite screen locked
Remove the battery first. Then hard reset the Incite. It woks for me, but you may need try sereval times. Good luck.
Jun 06, 2009 | LG Incite Cell Phone
I accidently put the lock on my oven.Now the lock will not come off. Please help
Hi
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above.
To lock the control panel and both oven doors:
  1. Press and release Cancel.
  2. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
To unlock the control panel and both oven doors:
Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
Please see this link for more information as how to disengage the lock on your Jenn Air Oven---
Door Lock On Oven
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
My oven is in lock mode after i had cleaned it. I can't open it now and the lock light is on.
Control panel and oven door lock
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked.
  1. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
Dec 22, 2008 | Jenn-Air Electric Double Oven
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Amana AGR5725SDS Gas Range Logo
56 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
