Question about Pitco Frialator SG14 Deep Fryer
Pilot won't light
I just purchased a turn key food operation.....I cleaned out the fryers and when i went to ignite the pilot it won't light
  • burzerko
    burzerko May 11, 2010
    I need the model number and s/n number if possible. I also need to know if it has electronic ignition or a standing pilot light.
  • 254 Answers
You have one of two things going on here either a thermocouple or a pilot safty valve failing. If you hold in the g/v button and the pilot will stay on but then go off when you let the button go you have a bad thermocouple. The 2nd is another option possibly installed on your fryer which is a pilot safty device it will have a large red button usually accessible from the outside or behind the front cover. Also you need to make sure you have gas present to the unit as well.
Posted on Jun 09, 2008
Pilot light won't turn off
Any parts been changed? valve might be wearing out.
Apr 23, 2013 | Imperial IFS40 Deep Fryer
I have an imperial fryer. Pilot is on but main burners don't ignite. Pilot looks normal & thermostat clicks when turned
Number 5 is your thermopile/pilot generator. It is a pilot generator that does 2 things. It holds open the valve with a safety magnet and it operates the safety valve solenoid whenever the control stat calls for heat. Overtime they get weak and will hold the pilot but not operate the valve solenoid. I would replace that pilot generator.thermopile and party on!
Jul 30, 2012 | Imperial IFS40 Deep Fryer
My deep fryer pilot somtimes goes out after burners ignite
I assume this is a natural gas fryer....Are your jets clean? That is an issue sometimes, and those are the small holes that your flames come out of....Is your gas line clogged anywhere....? I don't sell Dean fryers, not too impressed by that brand, as they leak quite often, and then Dean won't honor their warranty I'm not as familiar with their products, however on some brands, the thermostat dial itself should not be turned to the holding temperature until after it lights and is fully on...Do you turn it to say 350 degrees right away or wait for it to light before selecting your temperature? Thermostats themselves going bad is the number one issue with fryers, so it could be that. To clean out the burner jets, we use a compressor and blow them out clean...You can also use a small brush or skewer to clean them out. I would eliminate everything you can that has no costs involved first, and then move to parts that you have to purchase. If you need a thermostat, I could get you a price on Monday... Our toll free number is 888-542-5959, Restaurant Equipment Outlet, Cincinnati, Ohio. We would need the brand/model number and serial if you have it also. Our service tech who specializes in gas products is off Monday, but there are other people there who can help and get you pricing on parts. I won't be in until after lunch myself Monday, but check out what you can, and if nothing works, then call us on Mon or Tues next week.
Everything is closed up until Monday, so we can't order or get pricing over the week-end. Good luck, hope this helps.
Nov 22, 2011 | Frymaster Dean SR42G Deep Fryer
45C- Flame and pilot went out during operation, Pilot won't relight.
If your pilot is a manual ignition model, make sure that the thermopile is clean (free of soot), it is the cylindrical piece of metal behind the pilot assembly which is heated by the pilot flame, a very small amount of voltage is generated by it to open pilot and main burner valves of gas valve.
Jun 03, 2011 | Pitco Frialator 45C Deep Fryer
When pilot is lit and white dial is turned to ON, fryer will not ignite when the temp dial is turned from off to 350
Make sure the knob on the gas valve is turned to the ON position after lighting the pilot. If the fryer won't come on.... 1. The pilot flame may be weak causing low millivolts. 2. The thermostat is failing. 3. The pilot flame may be good but the pilot generator may be weak causing low millivolts. As this unit operates on less than 1 (one) volt DC.... you can try to jump the thermostat leads on the gas valve to see if it comes on. If it does... change the thermostat.
Aug 05, 2010 | Pitco Frialator SG18S Deep Fryer
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Imperial fryer IFS-40
I had a very simular problem. My fryer would do exactly as you described, but sometimes the pilot light would stay on until the burners tried to re-ignite and then it would go out.
I finally had to call the gas company. They took the pilot light apart and cleaned it. The fryer works perfect now.
Hope this helps!
Oct 18, 2008 | Imperial IFS40 Deep Fryer
Vulcan Deep Fryer Need to Light Pilot
you have to hold the knob in after pilot is lit for at least one minute
Jul 09, 2008 | Vulcan EF3 Deep Fryer
Pitco Frialator SG14 Deep Fryer Logo
117 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
