Question about IBM ThinkPad A31 Notebook
WHEN I START MY IBM THINKPAD A31, I SHOWS THE IBM SIGN AND THEN IT SAYS 0190: CRITICAL LOW BATTERY ERROR SEE IF YOU COULD HELP ME. THAN.
    President:
  • 2,653 Answers
Yeah it's a pretty common problem with certain ThinkPads.
Here's a good place to start if you wanna know how to fix yours.
I'd recommend signing up for the forums and posting your question there since you'll get a lot of specific support from fellow ThinkPad users ;)
Hope this info helps!
Posted on Oct 09, 2010
0190: critical low battery error
When old IBM Think Pads fail to boot it is usually because the CMOS battery has worn out. It is very easy and inexpensive to replace. Youtube has numerous videos showing how to replace it e.g. https://www.youtube.com/watch?v=8ZI-8Q2j-zQ
Jan 24, 2018 | IBM ThinkPad A30 Notebook
0190 critical low battery error
push the power button at the same time with thinkpad button, and fast press F1 key.
you should need to do this 3 times to fix the problem.
May 14, 2011 | IBM ThinkPad T20 2647 Notebook
What should i do for 0190 critical low battery erroe in ibm r52 laptop
Normal 0 If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Oct 06, 2010 | IBM ThinkPad R52 Notebook
IBM Thinkpad A31 2652 wont switch on
This is bad news, the smell you have noticed from the ThinkPad is most likely caused by an electrical short in the power circuit and the cost of repair would not be a cost effective solution, a replacement motherboard may not be available because of the age of this model ThinkPad.
You maybe able to retrieve your data from the hard drive by removing the hard drive and connect to an USB hard drive adapter then connect it to a working computer's USB port. This computer will see this drive as an external USB hard drive and you can copy the data off this hard drive.
Feb 28, 2010 | IBM ThinkPad A31 Notebook
Ibm a31 0190 erroe
Error 0190 means you need to charge your battery. Either your battery is not charging properlty or your charger is not working anymore. If the computer works while plugged in and gives no error then it would be the battery that needs replacing. If the battery is a few years old then you may want to order a replacement. The Thinkpad A31 uses the ThinkPad Ultrabay 2000 Li-Ion Battery. You can purchase a replacement battery from this website:
http://shop.lenovo.com/SEUILibrary/controller/e/web/LenovoPortal/en_US/catalog.workflow:item.detail?GroupID=38&Code=02K6646&current-category-id=4364BD0F20B94413B5AD6E684D2848E9
If the laptop doesn't work while plugged in and you dont get any lights on the battery or power indicator on the front of the laptop then you may need a replacement. Depending on which region you are in you will need a different A/C adapter. You can find a list of different A/C adapters here.The A31 uses the 72 watt power adapters on this page:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4PJRRG#72watt
I hope this helps.
Nov 05, 2008 | IBM ThinkPad T20 2647 Notebook
IBM Thinkpad T21
This is a common problem with the T20 series Thinkpad. The problem is with the power management chip. Unfortunately, you will have to replace the motherboard to fix it. Since these are a bit on the older side, you can get a motherboard off Ebay at a reasonable price.
Aug 04, 2008 | IBM ThinkPad T21 Notebook
Thinkpad A31 2652
Sometimes a BIOS upgrade will cure battery charging behavior... http://www-307.ibm.com/pc/support/site.wss/MIGR-44450.html
Feb 16, 2008 | IBM ThinkPad A31 Notebook
IBM ThinkPad T20 - 0190 Critical Low Battery - Will not boot
i know what the error is what it is is a wire labeled "MAIN" has disconected to fix it you need to put the wire back into the tiny slot in right bottom corner of the right hole
i had the same error and just fixed it like 2 minutes ago it now runs perfectly
Dec 17, 2007 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad A31 Notebook Logo
393 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
