Question about Kenmore Elite 45986 Front Load Washer
Leaking in the back; I have never cleaned the filter (1 year). Could this be it? Cannot find manual.
    Scholar:
  • 42 Answers
It could be a filter. The first thing to check is the filter at the front. Remove the panel at the front of the machine, nearest the floor. You will find a little drawer or door. Open this and remove whatever is inside (quite possibly coins!). This might solve the problem, although I think it's more likely to be an inlet problem...
So the next thing to check is the supply hose. Is it properly attached to the machine? Is it properly attached to the tap at the other end? Can you identify a leak when the machine is filling?
You could also check the supply tap. Make sure it turns fully on and off. If it doesn't turn on or off properly you might need to call a plumber.
If the problem isn't a supply problem, it could be a drainage problem. If you can identify where and when the leak occurs you will be in a position to begin to fix it.
Another possibility is that the machine could have been damaged, e.g. by forgetting to take sharp things out of your pockets before washing. However, from your (albeit brief) description, I suspect the problem is a water supply problem and probably not too difficult to fix once you identify it.
Posted on Oct 09, 2010
Why does water leak after cleaning the filter?
If you have the manual handy, check the debris filter removal and reinstallation procedure. There may be some little thing that can spell the difference between leaks and no leaks.
Aug 11, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
I've had a oase clear water filter for three years now with no problems. I was cleaning it at the weekend I notice water leaking out off the function switch I would appreciate any advice thanks Dave
It should you did seat down correctly, take out the filter and put back in. You might want to inspect the rubber around the filter for wear.
Apr 07, 2015 | Washing Machines
Hf-360 leaking at cutoff valve
Hi
Going to the manual...it says if you have a leak like you are describing then you need to call tech support. this filter has a 5 year warranty. call 1-800-721-9243.For parts you can call 1-888-777-7962. Check out your manual here at http://www.culligan-store.com/pdfs/HF-360A_Rev_A-Manual.pdf Good luckne10810a
Feb 19, 2015 | Culligan HF-360 Whole House Water Filter...
I have the Mr Coffee Keurig model BVMC-KG5. It has only been used probably used less than 15 times. Now the water just drips out. Cleaned it per instructions which did not help. The machine was bought from...
It depends where the water just "drips out". It could be a leaking hose, or it could be the parts weren't put back together properly after you cleaned it. More information would be helpful.
Download Mr Coffee BVMC KG5 Manual
Feb 01, 2014 | Saeco Odea Go
1998 Ford Windstar 3.8L ScanTool says that Bank 1 is lean
if your getting oil in the air filter area, you have a leaking intake gasket or a leaking head gasket, run a compression test on it,
if the compression is where it should be on all cylinders then its a leaking intake gasket!!!
Mar 04, 2010 | 1998 Ford Windstar
Water Filter leaking after changing filter
There's probably some particles that got trapped in the filter purge valve ( the red button) preventing it from closing all the way.
You may be able to clean the valve while the filter top is still in place. Try using a small brush. A toothbrush may work if you cut off the handle. Hold the button down while you clean the inside of the valve. Then take a
spray bottle and put the sprayer tip on stream. Flush the valve from the inside.
If that did not do it, next step is to remove the top from the water lines, and flush the valve out.
Jul 19, 2009 | Culligan Under Sink Water Filter
Craftsman Edger 536-797520 is leaking gas from the air filter
The needle valve is sticking open. The carb needs cleaning and diaphragm replaced. Probably best taken to a shop unless you have experience with diaphragm carburetors. Dwain
May 27, 2009 | Craftsman Gas Mini - Tiller/Edger
I just turned on my ac for the first time this year. I found leaking on my carpet. I had to change my filter and found ice on my pipes. also the area around the unit was damp. Did i fix the problem by...
The ice buildup comes from low refrigerant or poor airflow.
Is your indoor fan runnig OK?
Are your evaporator coils clean of dust and dirt?
If fan is good and coils are clean, call a service tech to check your refrigerant charge.
Mar 09, 2009 | Goodman CPLE24-1 Air Conditioner
Danby Silhouette leaking
check that the removable bucket did not alter a water guide near the cooling fins
Jun 05, 2007 | Danby DDR600R Silhouette Dehumidifier
Kenmore Elite 45986 Front Load Washer Logo
20 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
