Question about Tatung LD23HL Monitor
My Tatung LD23HL Flat screen will not turn on. Is there a reset? When plugged in the power light blinks Orange.
  • 50 Answers
Check the monitor to computer cord, sounds like it might be loose or disconnected. swap another monitor in and go to display properties to see if the tatung is a 2nd monitor. using the replacement monitor redownload the drivers and reinstall. turn off and hook the tatung back and it should recognize it
Posted on Oct 10, 2010
Orange light blinking will not turn on
Your TV may have a failing or failed power supply.
Jul 23, 2014 | Vizio VO Televison & Video
N300 router has a steady orange blinking light
The blinking orange power light suggests that there is a problem with your modem. The modem should be plugged into the top ethernet port of your router. Try turning off your modem for 10 seconds and then turning it back on.
Dec 07, 2012 | Belkin Computers & Internet
Screen has turned sideways
Right click on an empty spot on the desktop and scroll down to either the Nvidia or ATI control panel. Once you are in the control panel, look in the left hand pane and look for something that says, screen orientation or screen rotation. When you select that it may give you the orientation in degrees of a compass or rosary. Make sure you place the monitor orientation at "0" degrees. This will bring the screen back to normal.
May 16, 2010 | Tatung LD23HL Monitor
Tatung monitor Power light shows yellow light.
It sounds like your resolution or refresh rate is out of reach for your screen.
Restart your computer (even if it will be manually unplugging the power cable)
If you have no display while your computer starts up; you might have a hardware failure. Swapping your screen out, or plugging it into another computer (that works) will confirm if this is the issue.
If you can see the computer starting up you can press F8 (on your keyboard) continuously just before Windows can start.
Select "Safe mode" so that you will have the basics of screen settings.
Now you can go to control panel, display and click on the Settings Tab at the top. Change your settings to a rather default "1024x768" resolution and change your referesh rate to nothing more than 75hz under the advanced icon.
Hope this helps!?
Jul 07, 2009 | Tatung L17AMTN 17" Flat Panel LCD Monitor
Tatung V30DMTT 29.6 in. LCD Television won't power on
bad power supply,common problem w/tatung,re-build power supply
Jan 04, 2009 | Tatung V30DMTT 29.6 in. LCD Television
TATUNG P42HSMT
Also have a TATUNG P42SMT. Problem is the screen starts to turn green shortly after turning it on, then the screen goes black.
Sep 01, 2008 | Tatung P42HSMT 42 in. HDTV-Ready Plasma...
TATUNG LD23HL
I had the same problem you hear the click but it stays orange which is standby mode never went to red which is on, I also smelled a bit of a burning electrical smell, so I took off the back case and watched the main board sparking and smoking right in front of me, my power supply was fine, be careful before you order a new one. The trouble with mine is that's it's about 99.9% impossible to find a part for it.
Aug 20, 2008 | Tatung LD23HL Monitor
No picture, no status light
This isn't a permanent solution, but it has worked for me. The first time I found out about this solution was when the status light went out on my Tatung. I just left it unplugged and didn't plugged it back in for about a month and a half just to see what it would do. When the status light came back on, I knew if it ever did it again, I could try the same thing. Well, a week ago last Sunday, the status light went out again, so I just kept track of when it went out and when I plugged the power cord back in to see if the status light would come back on. Today when I plugged the power cord in, the status light came back on. That was 9 days. I don't know if it could be less than that because the last time I plugged it back in to see if the status light would come on was around last Friday. So it might have worked sooner. Anyway, this seems to work for me. I don't know what is causing it to lose power in the first place, but at least I know what to do.
Dec 23, 2006 | Tatung V30DMTT 29.6 in. LCD Television
Tatung LD23HL Monitor Logo
179 people viewed this question
Top Tatung Computers & Internet Experts
Tony
kj henriksen
kj henriksen
Are you a Tatung Computer and Internet Expert? Answer questions, earn points and help others
