Question about Panasonic Televison & Video
I am a digital virgin! Just plugged in new kuro 4280xd got HD Sky through input 4 working but tv will not show hdmi dvd when plugged into other hdmi sockets?! Why?!
Friend helped.
Posted on May 31, 2008
Why is there no power to DVD box?
Check your power cord and plug for damage, do a wiggle test with DVD plugged in and see if it comes on while moving and bending wire plug. press the helpful button
DVD power supply repair tips
Press Release Consumer Electronics Video Audio Camera TV
DVD Player Repair Guide Covers Every Detail
Jan 26, 2016 | Televison & Video
Sky new zealand say my hd z70rx5 is unable to recieve hdcp even though the specs say the set is HDMI AND HDCP complient,they say no rear projection is able to receive hd is this true,any help i would be...
Terminals and Connections Dual HDMI digital inputs with HDCP (High Definition Content Protection) offer an uncompressed solution to the transmission and display of high definition video and audio content. All JVC HD-ILA TVs also include dual auto sensing component video inputs, assuring the best possible picture quality whether a viewer is using DTV, D-VHS or DVD, and three S-Video (two rear, one front) inputs and four AV inputs (three rear, one front).
hdmi.gif High Definition Multimedia Interface
HDMI is a new standard digital connection between A/V devices, such as a set-top box, DVD player or A/V receiver, and a digital television. HDMI offers exceptional video and audio quality with a single quick-disconnect connector. It supports multi-channel digital audio transmissions and component video color spacing for true rendering of HD video.
We carry a full line of high-performance HDMI cables. See them here...
Audio Features The JVC BBE High Definition audio system with Advanced HyperSurround and Active Hyper Bass includes two direct-drive speakers mounted underneath the screen for rich, expansive sound that fills your home theater or TV room.
Aug 06, 2008 | JVC Televison & Video
Samsung tv 32:inch no LE32R74BDZ WILL NOT WORK WHEN CONECTED WITH HMDI CABLE ,SCREEN GOES GREEN. SO I USE COMPOSITE CABLES .I HAVE A FOXSAT HD SKY BOX. BUT I WANT HD PICTCURES. AS I HAVE AN HD BOX . IS IT...
We need to narrow things down . If you have a dvd player that has an HDMI output plug that into the HDMI input of the tv with a diffent cable than the one for the sky box. If color is still green then the main board on the tv is bad. If the picture is good then Either the cable used for the sky box is bad or the sky box is bad.
Mar 25, 2010 | Televison & Video
I need a wiring diagram to connect a samsung tv, sky+HD, DVD recorder, Wii and Playstation 3...thnx
all you have to remember is out of one into the other IF got Ariela on house that goes into sky then out of sky in to DVD recorder and out of that and into tv
on back of sky hd if you are going to use HDMI cable put cable into sky box and other end into tv ( you will have ot put tv on HDMI input/source)
or use scart lead in stead
THIS DEPENDS ON HOW YOU WANT TO CONNECT PLAYSTATION
everything else is colour coded
Nov 08, 2009 | Samsung 37" 720p Flat-Panel LCD HDTV
Bravia & Sky+HD, aspect problem
There is nothing wrong with you Sony Bravia TV and it suppport all HD and SD formats.
Are you viewing the HD version of the channel when it is showing a standard defination show. e.g SKY1 HD instead of SKY1.
This means that regular standard defination shows are in a 4:3 ratio and does not fill the whole screen. In order to view these type of shows you will need to tune to regular channel instead of the HD version.
You can check if a show is brocast in HD by going into the tv guide and checking for the HD symbol in the programme symposis.
Example
Apr 13, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Won't Show DVD Picture or Hear From Surround Sound Speakers
The lack of video in the DVD can be isolated to the DVD players output mode, if you are using the component video out on the dvd player then be sure to follow the componet out of Receiver to the tv component inputs, if you are using the HDMI from a DVD HDMI into RECEIVER HDMI then go to TV HDMI, you cannot mix component and HDMI on this model of AVR receiver and acheive results, in other words keep the COMPONENT to Component and HDMI to HDMI signal path, the results will be similiar quality audio and video UNLESS you are doing a blu-ray source which will result 1080P quality, all other video, HD results to 1080i, about the audio, if all 5.1 test tones are satifactory to speakers but on playback modes for DVD or HD tv signals all you are receiving is LR which is basically 2 channel (stereo) you need to enable a MULTI-CHANNEL capability input, this must be a option on the DVD Player Audio MENU output, be sure it is set for DOLBY DIGITAl 5.1 or DTS outputs, be sure to have the receivers digital input enabled if you are running optical cable or coaxial digital for the audio, you will be sending a multi-channel input to the receiver when the Receivers Faceplace LCD displays 5-6 speakers. If it shows only LR or two speakers it is not locking into a 5.1 audio input.
Feb 21, 2009 | Yamaha HTR-6130 Receiver
HDMI SOUND
True HD can only work with HDMI interface and is only available on some newer HD DVDs. Check the DVD to see if the True HD encoding is available.
Feb 11, 2008 | Onkyo TX-SR605 Receiver
Digital TV
It is HD ready, which means to get HD you will need to connect a HDMI cable to a HDMI source such as a SKY HD / VIRGIN HD SET TOP BOX or a HD DVD player to take advantage of HD.
Jan 22, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
