Question about Broan-NuTone N-8663RP Combination Light Fan Exhaust Fan
How do you change the light bulb in a 8664RP exhaust fan?
How do I change a broan nutone 8664rp from a single switch to a double switch?
You will have to pull new wiring to do this, you should probably call a professional.
Feb 04, 2016 | Dryers
15 year old bath fan/light noisy. rectangular 2 bulb model 164A-D
Could be that dirt and dust have collected on the fins over the years and are throwing them out of balance. You could try cleaning the fins on the fan.
The bearings may also be wearing out.
15 years is a good life for a fan.
May 03, 2008 | Broan-NuTone N-8664RP Combination Light...
I have a broan ceiling light and exhaust fan. We changed the light bulbs now the fan is really loud and makes noise it didn't before?
Did you use the recommend wattage bulb (or that was in there)?
If you used the same or a higher wattage bulb it may burn hotter. When bulbs "burn" (are on) they actually do burn-out and may get cooler (and not as bright).
Changing the bulbs may also have shaken dust loose, allowing the fan to turn more freely and quickly, and if the bearings/lubricated points which may have been worn now shake about causing more noise, or, dust got onto the fan blades causing them to be heavier on one part than another which will definitely cause it to shake about and make a lot of noise (like unbalanced clothes in a washer's spin cycle).
Sep 27, 2014 | Dryers
Controls, heating and turntable function normally, but there is an intermittent failure (approx 80 of the time) where the interior light and blower do not function when the microwave is operating .
follow this test and fix it; God bless you
1)
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
2)
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Oct 31, 2013 | Jenn-Air JMV8100A 1000 Watts Microwave...
If the light and fan do not work, do I need to replace the entire unit or just the motor/
I agree that it would be cheaper and a better investment if you were to just buy a new one. You never know what all it might need either so it's best you call a pro so he can pinpoint the issue for you.
Aug 05, 2012 | Broan-NuTone N-8664RP Combination Light...
Does the motor for a nu tone bathroom fan #86933-000 supposed to have 2 mounting studs opposite the shaft end? 8664RP
Yes. This motor has two studs opposite to the shaft.
Here are some pictures:
http://bit.ly/8YIowa
It is actually a better value to purchase the motor assembly S97017706 or S97017705, both fit.
http://bit.ly/asmjig
Nov 03, 2010 | Broan-NuTone N-8664RP Combination Light...
I have a Nu-tone 8663 RP Combo fan and light. The unit has been a great unit for a good number of years. The fan is shot. Motor bearings I think. How can I get a replacement fan assy. ?
I just ordered a replacement fan motor for this same exhaust fan. I got it from here, http://www.electricmotorwarehouse.com/aosmith/nutone/nutone1.htm
It's this one,
1.2 amps, 115 volts 60hz
1550 RPM; Shaft 1/4" x 1"
Rotation = CCW
3.3" Diameter Motor
2 Mounting Studs Opposite Shaft End
Motor Case Length 1 15/16"
2-Prong 115 Volt plug
For Model 8663RP, 8673RP
8664RP (86933-000)
86933000, JA2B104N, JA2B104
can substitute 99080517
Part # 86933
$43.95
It's on the first page, and the 8th motor on the page at the time of this post. Hope this helps!
Oct 20, 2010 | Broan-NuTone N-8663RP Combination Light...
Can't get the cover off to change the light bulb
The whole cover/grill/globe pulls straight down to expose the bulbs. There are two heavy "V" springs, one opposite the other, that hold the grill to the fan box. You need to overcome the holding power of these two springs to pull the grill down. If necessary, you may want to run around the edge with a sharp knife in the event it was painted in place.
May 20, 2010 | Broan-NuTone N-8663RP Combination Light...
After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
Nov 27, 2007 | Whirlpool MH7135XE Microwave Oven
Broan-NuTone N-8663RP Combination Light Fan Exhaust Fan Logo
136 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
