Question about Canon ZR90 Mini DV Digital Camcorder
I was watching a video on my camera and I carefully took it out to put in another. I may have bumped the wrong button but the next tape did not show any images. I got out more of my takes with known images on them but I still cannot view them on my camera. What did I do wrong?
    Genius:
  • 1,812 Answers
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Oct 10, 2010
How to repair a kodak video cassette T - 120 when tape comes off?
Need more info but I had a tape with videos I wanted and the tape was damaged so i bought a new take. took it carefully apart and put the tape in the new cartridge tape holder and works great now.
Apr 23, 2014 | Video Cameras
Something is wrong with the playback on our canon zr 400?
Mine did the same thing. I cleaned the head with a dry tape cleaner then instead of just showing a blue screen it started showing a screen with the video but with gray lines on it. Cleaned it a few more times but it still didn't work. Finally I came up with a solution they say not to do this but if your careful it will be fine. Get a bottle of nail polish remover acetone free and some q-tips. Dampen one of the q-tips make sure its only damp and not wet be sure not to get finger oil on your q-tips. With the camera tape port ejected and open lightly swab the head with the q-tip with nail polish remover do this as long as you like being sure to clean the whole head once complete let it dry for a few minutes when it drys it will be dull looking with a thin white film on it. Take a fresh q-tip ensuring you don't touch the cotton your going to use this to wipe the film off the head once complete the head will look shiny. try your tape and if it works it was a dirty head if it plays the screws up most likely your tape is dirty or messed up.
Richard L
Feb 11, 2009 | Canon ZR400 Mini DV Digital Camcorder
SONY HDR-HC1 TAPE ISSUE
With camera powered on try depressing the "Reset" button with a pencil/ball point pen. Then try again it may help.
Jan 17, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
Canon ZR85 camcorder won't turn on
Steps for removing the tape from a totally dead ZR85:
1. Turn camera upside down.
2. Move "Open/Eject" button to full right position (toward lens).
3. Manually push tape door open.
4. On the metal surface that sits between you and the tape, there is a very small screw. There is probably a yellow sticker next to the screw that says "Do not press on this part". With a small jewelry phillips screwdriver, remove that screw.
5. Push the metal plate (with tape) in the direction ofr the door and lift slightly. The metal assembly holding the tape comes loose, exposing the top of the tape.
6. Pull the tape upwards (out of the camera). At this point, the tape will still be engaged in the play heads. With the cartridge out far enough to see the heads, reach in with your jewelry screw driver and carefully lift the tape over the heads, and free from the camera.
7. Use the eraser on the end of a pencil to wind your tape back into the cartridge.
8. When re-assembling the mechanism in the camera, there are two curved slots on both sides of the piece you took loose. You'll need to thread these onto two posts inside before you place the top back in position and put the screw back in.
May 10, 2008 | Canon ZR85 Mini DV Digital Camcorder
Camera tape to a vcr tape
have you tried to plug the cord with the yellow and white plugs into your tv and the other end into your camera...on our tv we have to press tv/video on our remote to watch it....hope this helps!
Feb 17, 2008 | Video Cameras
Panasonic S-VHS-C movie camera
1. Take out the tape - AND TURN THE CAMERA ON.
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on you should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS
CREDIT TO LABBER
Feb 16, 2008 | Panasonic Palmcorder PV-DV53 Mini DV...
Panasonic VS5 MOVIE CAMERA
1. Take out the tape - AND TURN THE CAMERA POWER ON
6. Turn camera off
7. Next time you turn camera on y ou should be able to view tapes and record.
THANKS AND CREDIT TO LABBER
Cannot record or play
I had the same thing happen to my Sony DCR-TR7000 NTSC. I plugged in the AC power supply and it worked fine. So I fully recharged the battery, removed the Hi8MP cassette that was in it, put in a new one. The problem went away and when I reloaded the old cassette, the problem was gone. Don't know why, but this process seemed to fix it.
Nov 24, 2007 | Sony Handycam CCD-TRV107E Camcorder
Playback Problems
THE FOLLOWING SOLUTION FROM LABBER (CREDIT TO HIM)
I did have a similar problem as above, and has not been able to use the camera for a long time as power turns itself off in less than 2 mins. I tried the solution #3 (by labber) above. which i have copied and pasted below .
1. Take out the tape - mine stayed on longer (without blinking) when the tape was not in.
6. Turn camera off
THANKS LABBER
Nov 13, 2007 | Panasonic NV-DS29B Mini DV Digital...
Sony DCR-HC38 not recording or playing
try to clean the video head...just forward a blank new tape 5 times...until the head is being cleaning...dont use a video head cleaner...just think using a sand paper to the head....it damaging the head
Aug 08, 2007 | Sony DCR-HC38 Mini DV Digital Camcorder
Canon ZR90 Mini DV Digital Camcorder Logo
20 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
