Question about Dymo LabelWriter Twin Turbo Thermal Label Printer
Labels had gotten stuck in both sides. cleared out but some still stuck in there. labels will load but throws out multiple labels at a time and wont print. keeps saying out of paper. how can I open up to get roller out to clean it off and make sure no more label is stuck in there?
    President:
  • 2,777 Answers
Yikes, it is not really meant to be disassembled like that, it will void your warranty. If it is having difficulties I actually suggest you speak with Dymo directly and do a warranty claim on the unit. I am betting nothing is stuck down there, something has actually malfunctioned from a hardware standpoint on the printer.
Thanks
Tim
Posted on Oct 09, 2010
Label writer 450 is only printing half a label and then the blue light flashes like it is out of paper. New roll, worked fine before it ran out
Make sure you use genuine DYMO labels, not compatible ones. Also, make sure you select the right size in DYMO Label.
Disconnect the USB cable and the power cable to reset the printer. Check if the roll is loaded properly - the holes between the labels have to be on the left. Connect the power cable. If the blue light is solid, connect the USB cable and try to print.
Check the DYMO Label version (Help > About). If it is below 8.5.0, you have to update it.
^CM
Feb 08, 2013 | Dymo ® LabelWriter® 450 Series PC...
2004 Lincoln LS 3.0 multiple miss fire issue.
A bad injector also shake the pcv and see if you hear it
you should have been had a check engine light with those will turn on check engine light how old is the fuel filter
May 04, 2017 | Lincoln LS Cars & Trucks
STUCK LABEL IN THE P-TOUCH QL-500 LABEL MAKER, This is now the third printer I have purchased and replaced because of stuck labels on the rubber roller, this is a great printer until this happens. Any...
I downloaded service manual
You need to remove the top cover
Remove the curved cover 1st , has 2 plastic pins to press inwards
Lift the curved cover upwards
Remove the darkcover beneath the labels
At the back 5x self tapping screws
At the from 2x machine screws, left hand one is under a label
Prise off the cover by inserting a screwdriver at the back edge
Voila
Remove the stuck label
Reassemble
Apr 01, 2011 | Office Equipment & Supplies
My Dymo Labelwriter 450 turbo feeds out 4 labels each time I print one. The print setting is on one label. The first one prints and the next three are blank. If I try to use the reverse button the printer...
Multiple label feeding usually occurs because the sides of the spool holding the roll are not squeezed tightly together. Make sure there's no gap between the labels and the sides of the spool. If this doesn't help. take out the labels and blow a blast of air into the feed slot. There is a sensor inside the slot on the left that detects the hole in the labels, and maybe it is blocked.
Jan 26, 2011 | Dymo LabelWriter 400 Thermal Printer
Although no paper seems stuck in the printer the display keeps repeating paper blocked
Although you didn't mention what type of printer, most of the time that I have seen this error it has been a paper issue. It can be the tiniest of pieces of paper that has torn off and gotten stuck somewhere inside the printer. It can also be a small piece of a label if you use the sticky labels in your printer.
If you have done everything to clear the paper path, opened the doors, and pulled out the trays, you may want to try spraying some canned air into the printer to see if anything comes loose. The only other way I have been able to fix this issue is to tear apart the printer and find the tiny piece of paper.
Jan 20, 2011 | Computers & Internet
VCR won't eject tape - timing of loading mechanism is off
Now-a-days most of the gears are made out of plastic(HDPE, if I remember correctly), when the rewinding command is given even if one gear tooth is worn/broken it will throw the entire timing out of 'gear'. Since the problem has already occurred, and, this is the only function that has malfunctioned my advice would be to leave it as it is! ('cos repairing/replacing it is manual & therefore a costly affair plus there is no guarantee that the replacedment will function properly)....sodeep
May 09, 2009 | Sony SLV-940HF VCR
A piece of clear label has stuck to something inside
You can go here and download the service manual for that printer. But as far telling you exactly where that "label" is . .I would guess either the drum or developer ..
Dec 22, 2008 | Brother HL 5250DN Laser Printer
My printer display keep showing " Warning, Ribbon in", cannot print multiple label at a time
i have the same problem , but my printer is ZEBRA S4M ZPL
my solution is:
in your barcode software: change printer settings: 1 and 2
1 . in media setting : change media type --> Thermal transfer
2. in documents options , configuration --> use printer settings
by Lin Yu Hsien
Oct 15, 2008 | Zebra Z4Mplus Label Printer
Dymo LabelWriter Twin Turbo Thermal Label Printer Logo
82 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
