Question about Dryers
Kenmore dryer runs but no heat. I have ohm checked the heating element, all thermostats and the thermal fuse. All ohm okay. I also checked voltage throughout the circuits from the main block to each component. All voltages are good. I also checked the timer motor. It ohm checked okay. I am stumped at this point
    Brigadier General:
  • 4,088 Answers
Did you read ~220 volts AC across the two slanted blades of the power socket? The motor and controls usually run on 115 volts. When the timer is set to dry, press start, and look for ~220 volts at the heater element connections. (Don't let the heater reach full heat if it starts working!) You may have to short the door switch connections to get the unit to run. If you don't read 220 volts at the plug, check the output from each breaker of the dryer pair (should read 115 volts to neutral). Hope this helps!
Posted on Oct 09, 2010
Why is my dryer running, but not heating up or drying the clothes?
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Jun 23, 2014 | Kenmore Dryers
Sears dryer, model# 110.87562601.
I have a Sears dryer, model # 110.87562601.
#1 reason of dryers going bad is woman's bra's....the medal sewed in the cloth itself for support comes out and goes into the small holes and hits the heating element on both sides and shorts it out...Change the heating element....It's in back of dryer.
Oct 06, 2017 | Kenmore Dryers
Kenmore series 90 electric dryer will not heat. Have replaced thermostat-thermal cutoff and thermal fuse. tried bypassing all by connecting wires with electric tape to test with no results - There are no...
Okay Element should read around 38 OHMS if okay providing the voltage is at the element then it should heat, if no volts then check stat , cut outs and timer, in that order
Feb 22, 2011 | Dryers
Kenmore elite elec dryer, 110.64972300. runs no heat
Pull one wire off the element and start the dryer in a heat cycle . Check power from that wire to the cabinet . Touch the meter to the terminal you pulled that wire off of , and check that voltage . You cannot get correct voltage by checking across the element . Trace the wire NOT getting 120 volts . It will either go to the timer or motor . It will lead you to the problem .
Apr 28, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore electric dryer model number 86860100 dryer not heating.....cleaned out vents not the problem....everything else seems to work.. I had seen in the past it glow in back of the dryer so I turned out...
hello there:
Testing with an ohm meter checking on a dryer....
These are the places that pass voltage to the heater elements on an electric dryer. In order to check a dryer for no heat, here is a list of places to check. Remember to always unplug the appliance before starting testing with an ohm meter. Always remove wires from the part you are testing with an ohm meter ( write down what goes where first before removing any wires ).
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuity across a good element 8-12 OHMS
Jan 09, 2010 | Kenmore Dryers
The dryer is not heating
Hello there here is a list of things to check
7. Heat elements-Test heater element with an ohm meter. You will read continuity across a good element ( 8-12 ohms is an average element ).
But darn it, I don't have a Ohm Meter....
To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only. To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
How to take apart information for GE style dryers
How to take apart information for Inglis - Whirlpool - Kenmore dryers
How to take apart information for Maytag dryers
How to take apart information for Frigidaire and White Westinghouse
Jan 09, 2010 | Dryers
Kenmore series 70 dryer will not heat up replaced heating element thermostats check ok with ohm meter
If heating element was replaced and still no heat, Then what I would do is test the voltage current in the wiring and see if there is actually power to the element.
All parts to make dryer heat are:
heating element
thermal fuse
thermostat
timer
any one of these units can be faulty
Oct 10, 2009 | Kenmore Dryers
Kitchenaid superba dryer won't heat Where is the heater fuse located?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
7. Heat elements-Test heater element with an ohm meter. You will read continuityacross a good element ( 8-12 ohms is an average element ).
To check the thermal fuse  - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.To check the thermal cut-out  - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
How to take apart information for Admiral, Norge, Magic Chef and Crosley
Mar 30, 2009 | KitchenAid Dryers
Kenmore Dryer won't heat
ok you moving in right direction but you jumped a step,,you already checked the thermal cut offf and the operating thermostat,,those where the two on the side of the heater housing,,you should have checked the thermal fuse and the thermistor,,they are on top of the blower wheel housing tuck a lttle to the left,,since you seem that you know what your doing just jump them out starting with the thermal fuse,,,keep me posted on the job
Jan 04, 2009 | Kenmore 63942 Dryer
Dryers Logo
Top Dryers Experts
