Question about Whirlpool Washing Machines
F 11 code on front loading whirlpool washer - Whirlpool Washing Machines
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Posted on Oct 09, 2010
  • 36 Answers
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
take off the bottom kick panel locate the drain pump now there will still be water in the washer so take caution when following this procedure i use a shop vac and suck all the water out of the drain hose to prevent a mess then the frount of the drain pump will screw off check it for blockage or damaged impeller blades
Posted on Dec 28, 2007
duby1990
  • 370 Answers
SOURCE: F30 error code on whirlpool front load washer ''Duet''
You have a problem with your soap dispenser. This has been a very common problem. You need to order W10161052 Actuator, W10157886 Dispenser, 8183186 Actuator Motor. Put these new parts in and you will be fixed.
Posted on Nov 19, 2008
duby1990
  • 370 Answers
SOURCE: Whirlpool Duett Front load washer, DFL code door won't unlock?
Here are the steps to unlocking the door manually
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Posted on Nov 21, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
techbuster
  • 5081 Answers
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
Posted on May 21, 2010
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool Duet Front loader Washer Model GHW9150PW4
there is a book inside the washer in bottom or back that gives you the trouble codes
Jun 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
The washer stopped in the middle of a wash cycle. The error message was 11 F. I turned it off and turned it back on and washer stilled stopped and repeated the error message.
Hi
An "F-11" error code on a Whirlpool Duet could cause your washer to become inoperable and stop in the middle of a load. The cause of the problem could be a number of things and may require new parts.
F11 can mean anything from motor to motor control board to ccu board to wiring harness connecting ccu to mcu to motor.
Identification
The "F-11" code could appear with the dash or without the dash on the LCD screen. Be aware that there is also an "F-H" code that could look similar to the "F-11" code. Listen for 11 beeps to go along with the error code's first appearance.
Effects
The error means that there is no communication between the "Motor Control Unit" and the "Central Control Unit." This means that any operation selected like "Pre-wash" or "Large Load" cannot be sent to the motor for the washer to operate.
Prevention/Solution
Open up the washer panel to check the wire connections between the two units. If any plugs are loose or unplugged, reconnect them. Check to make sure none of the wires are stripped, rusty or broken off. After you reconnect the wires, rerun the washer to see if the error appears again.
Warning
If you do not know or understand the inside components of your Whirlpool washer, leave the job to a professional. Contact the store where you purchased the washer or Whirlpool customer service directly.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F11 and/or dl code on a whirlpool duet front load washer
F11 is:
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check for:
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Check the above link for a detailed article about the f11 error code.
Courtesy:JSrock
Apr 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 11 error code on whirlpool duet washer.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
this is for error code f 11
thanks.
May 02, 2009 | Whirlpool GHW9400 Front Load Washer
Washer error code is F 11. will not let me reset
There is a small cover on the front bottom of the washer. Remove it and there should be a door release rod that you can pullto unlock
Apr 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washing machine
f-11 is a motor control unit error.
These codes and more details are printed on the service technician diagnostic manual that is affixed to the inside of the washer's front panel.
Unplug your washer, and unscrew the three 1/4" socket screws at the bottom of the washer. The manual should be taped to the back of the panel, and the code and some recommended procedures will be right inside.
May 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
94 people viewed this question
Dan Webster
Dan Webster
Sal De
