Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
Troy built edger TBE515 ECruns but starting to smoke pretty bad @ times its a 4stroke its got straight gas in it and oil in case is at operational level?? its too new to smoke like that1!! is there anything i or my mechnic brother can tackle THANKS
  • Roy Cagle
    Roy Cagle Oct 09, 2010
    I see from an engine diagram that the engine has a rocker cover. That tells me it has overhead valves or OHC. Can you guys check and/or adjust the valve clearance for the intake and exhaust valves on this thing?
2 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: looking for a owner's manual for a troy built
This link should get you where you need to be:
lawnandgarden.manualsonline.com/ex/product/headline/m/troybilt/d/edger/p/TBE515
Jim
Posted on Sep 17, 2010
How to put on new belt
https://www.partstree.com/parts/troy-bilt/edgers/tb516ec-25a-516-966-troy-bilt-edger-2011/general-assembly/
Zoom into the diagram, remove (item 45) belt cover to expose the belt and pulleys. Take note of how the belt is routed.! you will need to follow the same route with the new belt. You may need to remove the Blade guard (item 40) if the belt doesn't fit over the head of the guard. There may also be a sprung idle tension pulley, which will take up the slack in the belt once replaced. Looks pretty straight forward.
Apr 19, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
Excess white smoke coming from exhaust of TB 75SS string trimmer
This model is a four cycle engine meaning that it does not a mix of gas and 2 cycle oil. You just fill it like your lawn mower, gas and fill the crank case with oil
May 25, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Manual for singer sewing machine
is this an old leather machine?
Jul 12, 2012 | Sewing Machines
Trimmer is producing alot of white/blue smoke, got it to start and it will keep running, but the smoke seems excessive when using it. Not sure what the problem is.
This engine does NOT used mixed gas at all! It uses straight unleaded gas. If your using mixed fuel of any mixture ratio in the engine it is really going to smoke badly. What fuel are you using please?
Kelly
Jul 01, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy built 27cc string trimmer Model TB21 EC. What is the gas oil mix ratio?
4 cycle engines do not run on mixed fuel. Run on straight fuel. They have a spot to put oil in just like a lawn mover, and should be changed regularly. @ stroke engines run on mixed fuel.
Sep 27, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Starts but will not stay running. smoke blows out the back, would this have anything to do with the gas/oil mixture?
These amchines smoke a little, but if it is smoking a lot,.....either the gas/oil fuel mix has too much oil or the engine is badly worn. If it is the engine, power and acceleration will be lacking . Too much oil in the gas may eventually foul the plug...lest you mix up a batch at the proper ratio. 40:1 is good. 3.2 oz 2-Cycle oil to ONE gallon of gasoline. Always use fresh fuel in these small engines. If the mix is over 1 month old, dump it back into the can, pour it all into your car (won't hurt it) and make some new.
Aug 26, 2010 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Gas mix?
Straight Gas no mix for a 4 cycle.
May 16, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Runs well but burns oil ( blue smoke )
If not mistaken, the model number indicates a 4 cycle. Do you turn the trimmer over on it's side to make it do double time as an edger? Then expect some oil to creep past the ring pack and make it puff blue from time to time. Keep an eye on the oil level every time you set out to start work! If it does this when remaining perfectly upright all the time, then you may have cause to investigate into warranty repair...
Apr 11, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Someone borrowed my 4 cycle engine cultivator and put a gas and 2 cycle oil mix in the tank. Has that caused any major damage to the motor as long as I flush out with straight gas?
It shouldn't have caused any damage, I would empty the tank, float bowl, pull off the feed line and drain it. You might want some ether ('starter fluid') at hand in case there are traces of oil in the fuel lines making it reluctant to start.
Mar 14, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
119 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
