Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby shampooer dispensing - NOT a filter problem
I have a Kirby Ultimate G that is not properly dispensing the Kirby carpet shampoo. It comes out in only 2"-3" strips. I thought the problem was the little mesh filter - it just sits loosely in there and tends to fall out into the connector tube - but I secured it with plumbing tape and the problem still occurs. I have also checked the sponge filter and it is fine.
Please help - I am ready to take this thing to the pawn shop, since I bought it mostly for the shampooer!
Oh, and I have read the other responses to similar problems, so no need to post links to manuals or to Kirby customer support. I'm looking for direct solutions, please.
  • fleminglee Aug 29, 2008
    I have the same problem! I thought it was the mesh filter too and called for a new one (which they promptly send for free) but it doesn't work either. I don't think it is a soap problem because I have used plenty and it has happened since day 1. Takes forever and a lot of soap this way.
  • 3 Answers
I had the same problem and I called my local Kirby guy, he's great, helped me when I thought I blew my kirby up, it was just a cord and he wa able to tell me that over the phone. When I called him with this problem, he knew right away that it was only putting out a thin strip in the middle only. The first thing was I needed that little screen, the second was the hole where the screen goes has a white tube that goes from that hole to the bottom of the tank, its kinda in the corner and I never thought it would have anything to do with the problem. He said I needed to run hot water in it and clean it cuz I was going to have to blow in it, yes, with my mouth. I ran it under hot water for a few minutes and then with hot water in the hole, blew into it. I did this a few times, checking the tube ending each time. After a few times, water was shooting freely through the tube. Problem solved, I think, I'll be shampooing tonight so i'll know for sure then. An alternative to blowing with your mouth would be using a can of air, didnt think of it till now and I have 1!
Posted on Oct 01, 2008
    Problem Solver:
  • 5 Answers
Contact me at 1 866 416 7408 with all of your kirby problems or on the web at freetimeenterprises.biz
Posted on Jun 25, 2008
NOT ENOUGH SOAP!! I had the same problem just yesterday. I checked everything and found out that I did not have enough of the solution in the tank. If you don't have enough solution then you don't see the suds and that is why the water level goes down in the tank despite no suds! Hope this helps. Remember you should put 3 cap fulls of solution into the tank and fill it with luke warm water to the line.
Posted on Jun 30, 2008
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
I have a Kirby vacuum with the shampooing attachment. The shampoo/liquid comes out of the shampooer in a drizzle of liquid. There is no foam.
You need to check that the little round screen is in the hole where the hose attaches to the shampoo tank. My guess is that the little round screen is wedged sideways in the end of the hose. Here is a guide to help you further... http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Jun 01, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do i use my carpet shampoo system?
Please copy and paste the address below to the address window to obtain instructions for your Kirby Shampooer.
Hope this helps :)
Thank you for using Fixya!!!
May 15, 2009 | Kirby Ultimate G Bagged Upright Vacuum
G5 not dispensing anytyhing
You are missing the little screen that goes on the small hole in the tank where the shampooer hose attaches to the tank. Read this shampooing instruction guide for more info....
Jun 07, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Shampooing with the kirby
In the cap where you fill the shampoo, make sure the filter and components are clean
Apr 17, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Shampo system
here is a site that has detailed instructions for using your kirby shampooer.
the screen that goes in the hose is different from the filter (round flat sponge) that goes between the exhaust side of the kirby and the shampooer tank. The screen is what makes the suds...if its not seated properly or missing (or damaged) then it won't make suds.
http://www.greatvacs.com/shampoo.shtml
this site shows a picture of the piece I'm describing...its the 3rd picture down, called the gauze filter...still its different from the sponge filter....
also...make sure you go slowly with the kirby (and lower it to its lowest setting) if your carpet is heavily soiled....the enzymes in the shampoo are what clean the carpet (oils, grime, etc) and if its heavily soiled the suds disappear almost immediately.
Hope this helps!!!
Feb 03, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Tiara
try this shampooing guide
and make sure the brushes on the shampooer head are spinning and that the shampooer head (same height adjustment on the kirby when vacuuming) is set to the lowest setting.
Dec 09, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
293 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
