Question about Car Audio & Video
The lever inside of my toyota camry that is supposed to open the gas filler "door" won't opne it and I can't fill up my car.
  • 400 Answers
Look in your trunk...Behind the carpet on the side your gas tank filler is on. Should find a wire with a plastic hoop on the end... Pull it.
Posted on Oct 09, 2010
2007 Toyota Camry. Can't get the gas cap open. Pull up on the lever in the drivers side door but doesn't open gas cap?
Hi Marvin,I just watched this video on your gas cover not releasing,it seems a lot of these Camrys do this. The part that releases it comes loose,here's a video showing you how to fix.Seems it will be easier with 2 people doing it. How to fix fuel tank door opening system Toyota Camry
Aug 30, 2017 | Toyota Cars & Trucks
1997 Camry -rear left door won't open from inside. Linkges and snap on clips appears to be OK. Toggled the child saftey lever many times but the problem remains. What to do next and how?
really sounds like a linkage is off somewhere, could be up at the release inside the door,Sometimes hard to see. Could also be in need of some oil. make sure inside handle is not broke also. hope this helps and good luck.
Aug 12, 2012 | Toyota Camry Cars & Trucks
1988 toyota camry le I cant open the door to put gas in. the lever does not work
Remove to trim/carpet on the inside of the trunk by the fuel door. you can reach in and pop the release.
Oct 19, 2010 | 1988 Toyota Camry
Petrol flap will not open on a 1989 camry
open the trunk and look to see if there a by pass tab by the filler spout
Feb 23, 2010 | 1999 Toyota Camry
The lever won't open my gas tank. What can i do?
read the manual. There should be a cable in the trunk you pull as a manual release. If not pull the trunk lining fabric back away from the fuel fill area. You should see how to manually open the gas filler door
Jul 03, 2009 | 1999 Toyota Camry
The gas tank door won't open with the lever, only if I put something under the lever after pulling it up I can pry open the door
More than likely the metal spring on the inside of the gas door is broken where the plastic attaches. Have someone hold the fuel door lever in the release position while you gently use a flat head screw drive to open the door. The part should cost you less than $10 at Toyota.
Apr 22, 2009 | 1999 Toyota Camry
Fuel Door will not open
the cable from the lever to the door has broken. If you look inside the trunk, (sometimes you will have to pull the carpeted side down) right behind the gas door, you will find a short emergency release cable with a loop on the end - grab and pull the loop and your gas door should pop open.
Jan 12, 2009 | 1998 Toyota Camry
Fill gas tank
have toyota or any machanic check the filer in the gas filler tube.
Nov 03, 2008 | 1998 Toyota Camry
Seat belt does not move when i opn the door
If only one seat belt does not move when you open door then check the pink wire in the rubber boot passing from the door panel to the cabin around the door hinge, however if it is both seat belts that don't move when their respective doors are opened, the problem is in a little box located right under the hand brake lever, behind the shift lever, of course you have to remove some of the decor to get to it.
Oct 30, 2008 | 1991 Toyota Camry
My 2003 toyota tundra has a serious problem when i try to put gas in it. it keeps clicking off because gas seems to be backing up in the filler neck and the sensor shuts it off so i am continuously pulling...
hi you got a problem with the return pipe on the filler neck to the tank it proberly will have a non return valve on it causing a blockage so as your filling it creates a vacuum and won,t fill yates210456
Oct 01, 2008 | Toyota Tundra Cars & Trucks
Car Audio & Video Logo
14 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
