Question about M-Audio Mobile USB MIDI Controller
All my c-note keys are unresponsive - M-Audio Mobile USB MIDI Controller
  • 50 Answers
Oooh, sounds like a hardware problem. the matrix or multiplexors that control the "bank" of c notes sounds fried
much like a numeric keyboad where a group of keys works and a group doesnt work
try with the headphones it could also be output driver chip failure on the amp out circuit
Posted on Oct 10, 2010
TI 84 silver edition unresponsive keys
Remove all four AAA batteries. Press and hold the ON key for at least fifteen seconds then release it. Replace the batteries.
May 09, 2012 | Texas Instruments TI-84 Plus Silver...
MVP V Model CMV1000ADW
From the description it is the keypad control board problem, membrane "shorts" replacement only option.
Apr 04, 2012 | Maytag Appliances Over-the-Range Microwave...
I have the mytouch 3g i want to do a hard factory reset because im locked out when i do the home and power key an get to the selections i can scroll down to the optiion to factory reset but when i click...
  1. Power the device OFF.
    • Note: If the device is unresponsive and does not turn off, remove the battery and then re-insert it.
  2. Press and hold the Home key and the red End key for 30 seconds. Do not release the keys if the Startup screen appears.
  3. When the screen displays a warning sign, release the keys.
  4. Press the Home key and the Power key again.
  5. When the Android system recovery utility appears, use the trackball to scroll to and select Wipe data/factory reset.
  6. When the reset is complete, select reboot system now
Apr 29, 2011 | Cell Phones
My android 3g T-mobile phone has a blue light on top and won't turn on even when hooked up to desktop with USB. help!!
you need to do a hard button reset and this will fix your issue 100%!!! i found the info at tmobile.com/forums.
myTouch: How to Hard Button Reset Options
01-11-2010 10:59 AM
If the handset is locked, frozen, or unresponsive, you can perform a master reset it using the hardware keys instead of the menu. A master reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. It does not erase data stored on the SIM card or memory card (if available). To perform a master reset using hardware keys, follow these steps:
1. If the device is responding at all, back up your data before proceeding.
Note: The device must be turned on to synchronize or transfer files.
2. Turn off the device.
Note: If the device is unresponsive and does not turn off, remove and then reinsert the battery.
3. Press and hold the Home key and the Power key for at least 25 seconds, even if the Startup screen appears.
4. Release the keys when you see a black screen with a warning sign.
5. Press the Home key and the Power key again.
6. When the Android system recovery utility appears, use the trackball to scroll to and select Wipe data/factory reset.
7. Once the device finished the data wipe, select reboot system now.
Dec 24, 2010 | Cell Phones
Old keyboard still connected note worthy keyboard
when you start computer just press del and go to cmos bios setup and set usb keyboard setup enabled and save the setting.
Sep 08, 2009 | Targus Noteworthy Multimedia Keyboard...
Keeps rebooting, how do I do a master reset
The T-Mobile Dash™ includes a button sequence which can be utilized to perform a hard reset. This method is much more difficult to do but it will perform the reset if the menu options are not available.
Note: Before attempting this procedure make sure to backup your data using ActiveSync. All unsaved data will be lost.
Hard Reset
1. Power the device off by pressing and holding the Power key.
Note: If device is unresponsive remove the battery.
2. With the phone off press and hold both soft keys (The two keys directly under the screen, used to open menus.)
3. While continuing to hold the soft keys, press and hold the Power button for 1-2 seconds.
4. Continue holding the soft keys until you see a message that starts with This operation will delete….
5. Release the soft keys.
Note: If you see the standard boot up screen load steps 2 and 3 were not performed correctly.
6. A boot splash screen will appear, followed by a black screen prompting: Press Send to restore factory defaults, Other keys to quit
7. Press the Send key.
8. When prompted to powercycle device, select Ok
Note: Once the hard reset is performed it could take up to a few minutes to completely boot back up.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 14, 2009 | T-Mobile Dash Smartphone
Ipod touch 2g home key unresponsive
Hold the power botton and Home botton at the same time it will reboot and should work fine.
Mar 23, 2009 | Apple iPod touch
TI-84 Plus: Calculator Unresponsive
Try pressing the "On" button a couple times. That should work
Oct 27, 2007 | Texas Instruments TI-84 Plus Calculator
M-Audio Mobile USB MIDI Controller Logo
103 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
