Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore 106.53662300 - all of a sudden the ice maker is not working, not getting any water in tray?? Filter light is blinking to change? where is water filter?
fridgetech
  • 473 Answers
SOURCE: ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
Most common problem is a broken ice maker module.  Should also replace ice maker thermostat when changing the module.  Make sure fill tube isn't frozen first. If you take the ice maker out pull off the plastic cover and in the center of the wheel that kind of looks like a gear there are two little plastic studs.  If one is broke or they are pressed together then the module is bad. Make sure to replace the thermostat along with some silicone grease because a bad thermostat is what causes the module to break.
Posted on Oct 20, 2007
ctf1800
  • 4402 Answers
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Posted on Dec 08, 2007
  • 218 Answers
SOURCE: Ice Maker not Getting Water
There are two solenoid-operated water valves - one for the water dispenser and one for the icemaker. They're located near the water connection at the back of the fridge. There is no pump; the water pressure sends water to the icemaker whenever this valve is opened by the icemaker controls. Your symptoms sound like the coil is burned out on the valve. You can check it by disconnecting the wires and checking for coil continuity with an ohmeter. If the coil is open, replace the valve. Both valves might be combined into one assembly, so be sure you test both coils. Of course it's also possible that the trouble is in the icemaker itself, but a failed intake valve is more likely.
Posted on Jul 23, 2008
geemarie
  • 876 Answers
SOURCE: ice maker kitchenaid
You did remember to turn it back on? Mine has a handle that detects when the tray is full and you flip it up to turn it off and down to turn it on. Good Luck
Posted on Aug 01, 2008
  • 11 Answers
SOURCE: Kenmore Elite ice maker is not working & red light is blinking
Most likely a problem with the main ice making unit itself. I bought mine at ebay for $49 including shipping. Very simple to replace. You just swap the wiring harness and bottom plate. Takes about 20 minutes to do.
Make sure you do the IR led test. If you think you IR sender and receiver are bad to, $57 on ebay for the set. Most likely not your water solenoid in the lower back of frig (it gets the signal to turn on from the receiver module of the IR board.
Probably not your water filter (cuz the front water dispenser still probably works right?)
And probably not a clogged or frozen line.
Good luck. When it doubt, trust ebay!
Posted on Mar 16, 2009
I have a Kenmore side by side, model # 106.57032601 that I bought 4 years ago. The ice maker suddenly quit working. The refigerator/freezer work fine otherwise and I continue to have water from the...
Is your ice tray filling with water? If not, then I would suspect the water inlet valve (http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657032601/0582/0165000/K0607002/00012?blt=06&prst=0&shdMod=10657032601 - Item 10)
If it does fill with water, but does not eject the ice cubes to start a new cycle, I would suspect the ice maker motor(Item 37). BUT if it is the motor, that part costs $91.22 and you can replace the entire ice maker (Item 100) for $157.95
Jul 10, 2011 | Kenmore Refrigerators
Just replaced the water filter on our side by side Kenmore 53569202, thinking that may have caused our ice maker to quit working. when opening the door to the freezer, there is a red light blinking twice...
You could have ice in the water shoot which formed because your inlet valve is clogged. The inlet valve is locater in the back behind access cover. Melt the water shoot with a hairdryer and then replace your inlet valve. Fairly inexpensive and easy to change. The reason the water shoot becomes ice is the inlet valve get slower and slower water flow which gives it time to freeze on the way in to the ice maker. Hope i helped, Rate me.
Aug 27, 2010 | Kenmore 53562 / 53564 / 53569 Side by Side...
Ice maker is not making ice
Even though the water dispenser is OK you need to make sure the tray(s) in the ice maker are filling. The filter valve, located to the rear of the ice maker can freeze over and stop water flow. Check the supply line for the ice maker, it may be separate from the water dispenser.
Mar 24, 2010 | KitchenAid Superba Architect KSCS25INSS...
Feb 14, 2009 | Kenmore Refrigerators
Ice maker not working, light blinking
I contacted Sears repair service and had the Ice maker and control panel replaced.
Jan 09, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Ice maker not making ice
Sounds likw the water fill tubs is frozen shut, look where the tube comes into the freezer compartment and take a hair drier and thaw it out. Good Luck
Jan 07, 2009 | Kenmore 53642 / 53644 Side by Side...
Dec 08, 2007 | Refrigerators
Ice Maker Not making Ice
Water is in the tray and you have freezing temps? Can you tell me a little more? The flashing red light began when the ice tray filled and did not freeze? Let me know when possible, Thanks JT
Oct 23, 2007 | Kenmore 50522 / 50524 Side by Side...
Oct 19, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
206 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
