Strange that you have placed the same question that was apparently placed in 2014. Solution provided at that time was:
"L3-00 means that the scanner (the light under the glass) isnt moving correctly. You can reset it by pressing clear, interupt,0, interupt, 14,1, start button. Good luck"
Honestly, No it is really not worth fixing. Most of the error codes with the finisher deal with the stapler unit and the guides that move for the stapler to work. Do you know if the finisher has all of the up dates installed? If not, it may cost just as much to fix it. Sorry for the bad news... Make sure the copier is OFF and take the cable out of the back of the copier and push the finisher from the copier and use it as a stand a lone copier..... Good Luck
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
