Question about Linksys Wireless-G Broadband Router
I am having problems with my modem and wireless router. Someone told me I need to " redo my ip address to my computer but am unsure how to do this, can someone help me please
  • 340 Answers
To renew your ip address go to start, in the search box type cmd. A black box will come up with a C: where the cursor is blinking type the following... ipconfig /release and it will go through its thing. When the C: comes up again, type in the following.. ipconfig /renew This will refresh your ip address and hopefully allow you to gain access to the net once again. Let me know if this helps.
Posted on Oct 09, 2010
Testimonial: "Got it!"
Router crashing
Router Technical Support includes router set-up, password reset, security, configuration, settings, Wi-Fi security etc. of any router. Call : 1-800-243-0019.
Apr 13, 2017 | Motorola SURFboard Computers & Internet
I am trying to figure out how to connect my Linksys WRT54GS2 router to my Hughesnet HN9000 modem. I have already attempted what hughesnet website told me to do and it didn't work. I have it set up...
DHCP and static IP are two different things. DHCP assigns IP addresses, and static Ip just means that the IP address stays the same, and is not dynamic. You probably need to reset the modem to accept what it sees as a :"new" router. Turn off both router and modem. Restart the modem first, give it a minute to boot up, then turn on the router- in that order. It should be ok now.
Mar 11, 2017 | Cisco Linksys WRT54GS2 Wireless-G...
I disabled my smc wireless through the ip address provided. When I went to reable it, the ip page won't load?? Help please
You might be connecting through wireless before and now that you have disabled it, your computer is not connected to the router and that is why you are not able to display the setup page. You can use an Ethernet cable to connect your pc to the router. Once connected, try to load the router's setup page again through the provided ip address. If you are unsure about your router's ip address, check this out for guidance. click here.
Hope this helps.
Jun 27, 2011 | Computers & Internet
Internet not working through wireless linksys router but working when directly connected to modem
I think the problem will rely depending on the settings on your router, Follow these step by step solution on resolving the problem.
1. Connect the cable coming from your modem going through the internet/WAN port of your wireless broadband router.
2. I suggest you test your internet connection first by connecting an ethernet cable from your Wireless Router LAN port going to your PC NIC(Network Interface Card).
3. In order for you to setup your router, you should be using a web browser. Go through your router configuration by typing 192.168.0.1 / 192.168.1.1, on your web browser. The ip address depends on the manual of the router which default ip address is assigned to your router.
Illustration:
after enter the ip address, pressEnter and you should see a login box where you can type the username and password of the router.
You should check from your manual what is the default username assigned when you purchase the router. Since some routers have been using standard username and passwords.
You should use "admin" as your username and leave the password blank, press Enter / OK.
If you have a successful login, you should see a router configuration webpage where you can setup your router.
Look for the Internet Setup panel, select what type of connection you are using,
DHCP - for cable modems
PPPoe - for most DSL modems
if you are unsure, just check with your ISP.
Set the SSID to identify your router and assign a WEP (Wireless Encryption Key) under your Wireless Security section to encrypt your routers network to prevent others from connecting to your internet without any permission.
Feb 03, 2010 | Linksys Wireless-G Broadband Router
Modem is giving wireless signal, yet I need IP address so I can make network secure. HELP!
Is there any computer connected to the wireless modem with the ethernet cable.
If not you will need to connect the computer to the modem to check the settings of the modem.
Does it have DHCP server. Do you have any computer online through the modem. If yes, check the IP address on that computer. You should have Private IP address on that computer.
Click Here for more info about networking
Oct 08, 2009 | Westell Wirespeed VersaLink...
We keep getting dropped for known reason .
Your internet modem needs to be reset to find the router first. The modem will find the first address when rebooting the entire system or if something gets unplugged..
I've had great success doing the following:
First of all turn off ALL computers, routers, modem ...everything... Then connect power to the main routing source... usually you've got your modem plugged into this.. Just start the router first with all ethernet cabling etc disconnected. Then secondly, connect power to the modem... As the modem connects, it will find the router ip address first... then you are set to turn on the wireless, and the other computers... and the router should designate proper ip addresses for all the peripherals and keep them connected without dropping someone off to allow the other address on... Hope this is clear.... So first the main router, then the modem followed by everything else... Let me know what happens ... and if you need more help...
Mar 15, 2009 | D-Link DSL 300G+ (DSL-300G+) Modem
Need to redo wireless setup betw linksys & westell
You will need to assign a different ip address to the Westell modem - I am assuming that both the router & modem are using the same ip address 192.168.1.1? If that is the case, then assign 192.168.1.2 to the modem.
Mar 15, 2009 | Linksys Wireless-G WRT54G Router
Router/Modem IP
Try 192.168.1.1 or 172.16.1.1
Mar 14, 2009 | Apple AirPort Extreme Base Station
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Xoom x6 adsl modem problem
possible issue with freequent connection loss when going over 2 comp on a network are possible issues of collisions on the network meaning that sometimes more often then not, it is possible for two comp to end up recieving same ip address fr modem.
solution: first find out ip range supplied by the router in modem. then statically assign ip address to each comp
this is done by going into tcp/ip properties of either nic or wireless card and set to use following ex
NOTE: IP RANGE USUALLY LAST SET OF NUMBERS IN IP ADDRESSING TIPPICAL RANGE IS BETWEEN 10 TO 99
ip address: 192.168.2.12 (static ip address for computer)
subnetmask: 255.255.255.254 (generic subnetmask)
default gateway: 192.168.2.1 (ip address of router)
Oct 18, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Linksys Wireless-G Broadband Router Logo
257 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
