Question about Dremel 8000 01 Cordless Rotary Tool Kit Variable Speed 10.8 Volt Lithium Ion
I have a Dremel Model 800 cordless rotary tool 10.8V. While using it one day to sand a small piece of wood, it felt extremely hot to the touch. I turned it off for an hour and when I went to turn it back on it ran at the highest speed. No matter if I start at one on the rotary dial or go all the way to ten, the speed is at top level. Also the 3 red battery indicator lights do not work at all. Is there any fix for this I can do myself. I really can't afford taking it to a repair shop right now, not that I know how much it would cost to repair or if it is even worth it. Can you please help me, thanks.
  • 132 Answers
SOURCE: Model 800 Dremel cordless won't work
try putting the battery in the charger with the power turned off (unplugged from wall socket ) leave over night then start recharging fresh and dont disturb for 10hours after 10 hours see if any better hope this helps glenn.........
Posted on Nov 16, 2008
  • 257 Answers
SOURCE: Cordless Dremel variable speed stuck on maximum
Hi, There are several dealers in London who can help you solve your problem. The following link is has a list of those dealers with addresses and phone numbers:
Good Luck to you, this should Fixya!
Posted on Mar 02, 2009
  • 3 Answers
SOURCE: Dremel 395 rotary tool - not working
it is the coupling inside of it called a flex coupling and it seem s like it is made of wax or something. tomorrow i will go to home depot to see if they carry metal ones that won't break.
Posted on May 29, 2009
  • 44 Answers
SOURCE: Dremel 395 motor just stopped
if you cant afford a new one, and you are mechanically minded Id say why not give it a crack and open it up, could be something simple least it will give you some idea.
Posted on Sep 02, 2009
SOURCE: I have a Dremel Single Speed Model 275 that
The Dremel 275 (and other series) have a plastic coupler and spline that connect the motor shaft to the collet shaft (where the tools attach). The plastic fatigues and disintegrates, causing the collet shaft to stop, even if the motor is still running. The fix is about $5.00 --- two parts from Dremel. The 275 case is a **** shell that opens with the removal of six T-10 Torx screws.
Posted on Sep 14, 2009
How do I use the tool for detail sanding
See the purple line on the poster:
I like the cylinder ones. Run it on slow speeds to get used to how it moves. It's probably not a great choice for sanding anything you want flat. They are great for shaping curves though.
Sep 09, 2014 | Tools & Hardware - Others
I was working with the dremel and it shut down and would not turn back on, the motor was not hot. I'm wondering if it has anything to do with the brushes in the side of the motor housing?
My dremel started doing that too. If I rubbed the sanding drum along a piece of wood, it would start up again. I think the brushes and the copper armature get glazed over with non conductive dust and possibly insulation smoke which disconnects it enough to stall out. Change the brushes to the new ones in the kit. After a year of heavy use mine slowwed down to about 300 rpm and then died. A very nice tool but I prefer the Makita which is about three times this size just because it is longer lived.
Apr 09, 2011 | Dremel 395 Variable Speed Multipro Rotary...
I'm trying to install the felt polishing tip, and it's only a round piece of thick felt. How do I install it on my dremel?
there in the kit is a shaft with a screw tip on it, you need to thread the polishing disc on the shaft, the shaft has a threaded screw, not the internal type
Feb 06, 2011 | Dremel Variable - Speed Multipro Rotary...
Type of dremel to use for computer case modding
Dremel may not be the way to go. ABS and poly plastic likes to melt and ball up on a Dremel
Nov 20, 2017 | Dremel & Stylus Lithium Ion Cordless...
Where can i find an instruction manual for the clarke ct4009 rotary tool
i have a dremel cordless rotary tool but have no manual,if anyone has one for the Dremel Lithium-ion cordless 10.8 variable 5,000-35,000 rpm model 800,can you kindly email it or tell me where to download it from at
thanks "R"
Jul 08, 2009 | Tools & Hardware - Others
Dremel Model 395 Type 3 Plastic Drive Shaft Connection broke into pieces. Replacement needed.
You can call Dremel direct at 1-800-437-3635 and order the part. Let me know if you need more information.
Apr 14, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Useing a dremel stylus
I would call Dremel tech service at 1-800-437-3635 and ask them and also get a copy of an instruction manual for future use.
Jan 28, 2009 | Dremel Stylus Rotary Tool
I need a coupling
Call Dremel at 1-800-275-2052 and they can help with parts and schematicsHope this helps. Dave
Nov 08, 2008 | Dremel Variable - Speed Multipro Rotary...
Tasks usage
Cutting holes in wallboard, Removing grout, Deburring metal, Cutting fiberglass, Sanding in tight spots, Cutting the heads off stripped screws, Shaping metal, Cutting ceramic tile, Stripping old paint and varnish from woodwork, Removing window pane glazing, Grinding, Shaping and cutting in arts and crafts projects, Polishing metal, Engraving, Etching, Cutting marble, Cutting nails, Cutting plumbing pipe, Sharpening tools, Cutting wood.
Aug 27, 2008 | Dremel 764 04 Pumpkin Carving Kit Includes...
Is there a reset button for a Dremel Multi Pro?
When the brushes go on my Dremel, it just stops, sometimes erratically - no smell or burning.
May 04, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel 8000 01 Cordless Rotary Tool Kit Variable Speed 10.8 Volt Lithium Ion Logo
211 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
