Question about Husqvarna Chain Saw 20" Bar
Can't seem to get my oiler to work properly. oil emerges when i run the saw with the bar removed, but chain is dry and hot when run put together.
  • 26 Answers
Some saw manufactures design their oilers to only work with their bars. Are you running the mfg suggested or stock bar? Chain? Stihl Chain is designed to use 30% less oil because of oil groves cut into each drive link directed to the rivets. So if your running an aftermarket bar/chain, the oiling ports may not line up. Especially if it oils with no bar & chain
Posted on Sep 21, 2011
How to stop sawdust from coming into the carburetor section and how to adjust the chain oiler. chain seems dry.
Check to ensure the oil opening on the side of the saw housing is not plugged as well as the matching oil groove in the guide bar first. Turn the saw upside down and see if there is a + and a - sign near the sprocket on the bottom. If so, turning towards the + increases flow. Most new small saws oilers are non-adjustable.
Feb 23, 2015 | Stihl GUIDE BAR 16 in STHIL CHAINS
Tip
Checking your chain oiler
Chain oilers are a vital part of keeping your saw running well. No oil can even cause the chain to bind up. Over a period of time it can greatly increase the wear rate of your bar and chain reducing it's life. Chain oilers seldom go bad they just get clogged up with sawdust.
Remove the housing that covers that bar and sprocket. There are two plates on each side of the bar that set over the studs.They may be identical or slightly different depending on the saw but at least one of them will have a hole in it for the oiler. If you remove the bar and both plates you will see the oiler hole on the saw housing. This oiler injects oil through the plate and into a small hole in the bar where the chain picks it up and carries it around the saw. If this hole becomes plugged with sawdust it will keep your saw from oiling the bar proplerly. This hole should be cleaned out periodically. It's not a bad idea to remove the whole chain periodically and clean the chain guide all the way around the bar and get any sawdust buildup out so the oil can flow better.
on Dec 05, 2009 | Garden
Oiler mechanism to bar of ryobi 40cc 10532 18 inch
I get asked this question a lot , im gonna have to make a video on this subject someday .
but here:
1st ck your oil viscosity/SAE it should be 30 and say bar/chain oil
next dump out entire oil tank and wash out with kerosene (you'd be surprised what I seen come out)
then remove bar and chain , locate oil outlet it's in body of saw near adjustment screw , use a small can of air to blow in this port softly , use a touch more of kero to clean this all out , refill tank with proper oil !!!! and run saw (no need to put bar/chain back on yet ) might take several minutes but oil should start to flow out hole !! stop saw and reinstall bar/chain then run again .. fixed !! if no oil comes out ever your oil pump is gonna need some fixing
for a low cost oil I use filtered used motor oil cut down with a dab of kerosene
Jul 07, 2014 | Ryobi Factory Reconditioned 18" 40cc...
The saw is in excellent condition but when it is running it makes a clattering noise from the chain. The chain is A1 and correctly tensioned. MY suspicion is that the chian oiler is not working. Your...
normally when oiler is'nt working the chain will get hot and tighten up on bar causing load on saw, like the brake is on, check your clutch, it's probably where the noise is, remove bar and chain and start it and see if it's still noisy also when you have bar off run a stiff feeler gauge through the bar grove all the way around cleaning it out then clean oil holes out in bar. Good Luck hope I helped You
May 02, 2011 | McCulloch Garden
The automatic chain oiler does not get oil to the chain. Yes, it has chain oil. The black tube to the top chamber at the bar, seems to be plugged and I cant get it off to clean it out. Thanks, Steve
I have never seen an automatic chain oiler that worked. Even new ones don't seem to work. Just pour a little used engine oil on the bar once in awhile like everyone else does.
In theory there is a small piston that rubs on an eccentric at the chain sprocket, and that sucks in oil and pushes it through a hole, into the center groove of the bar.
But if the piston is dry, it won't pump.
If the holes are clogged with sawdust, it won't work.
Here is a video that may help:
http://www.ehow.com/video_4756894_a-chain-saw-bar-oiler.html
Mar 12, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The chain locked up with the engine running. noticed no oil in the oil chamber. what needs to be done?
The bar and chain got very hot. Try this:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up.
  2. PUT ON GLOVES; completely remove the chain from the bar. Hold the bar horizontal and install the chain in the upper bar groove, (mark one of links) rotate the chain one complete revolution. If it rotates freely without catching or riding up in the groove you can reassemble your saw try it.
If my saw I would seriously consider replacing the bar and chain but I cannot see what damage has been done. HTH
Lou
Jan 14, 2010 | Husqvarna Chain Saw 20" Bar
Chain binds saw dies saw runs fine with out bar chain on clutch bearing? help poluan 3416 16 inch 34cc
Is your chain oiler working? If you're using saw a lot and the oiler isn't working properly the chain will get hot and bind up especially if the chain is too tight. Tighten the chain so that you can squeeze it in the center of the bar, with your second and third finger on the sides of your fingers (not a very strong grip) and you should be able to almost pull the chain out of the bar guide but not quite. Clean the oiler hole in your bar where the chain oiler injects oil into the bar. You can also run your saw without a bar and chain and see if the oiler is pushing oil out of the injector.
Dec 04, 2009 | Tools & Hardware - Others
Jonsered cs 2250 fixed flow oiler can the oiling rate be increased i think its not getting enough as the chain is running almost dry
Dec 03, 2009 | Garden
Chain oiler does not seem sufficient
The chain oiler injects oil into the rear of the bar where the cover mounts over the sprocket. Take the bar off and clean out the oiler hole. There is usually some buildup of sawdust in the hole. Clean out the grove that the chain guide runs in all the way around the bar. You can see the injector nozzle under where that bar was when you removed it. Sometimes there is an ajusting screw there to increase oil flow.
Sep 12, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain oiler
take off cover to the bar, remove chain and bar. spray degreaser or hot soapy water in and around the interior housing. look carefully and you should see a small hole that is where the chain lube comes from. typically all you need is a good cleaning in this area. hope this helps.
Nov 04, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Husqvarna Chain Saw 20" Bar Logo
399 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
