Question about Refrigerators
Kenmore elite 54603600 refrigerator goes to 33 degrees instead of 37 and freezer to 5 instead of 0 cannot adjust at ll ref is too cold whats problem
    President:
  • 1,891 Answers
Ck the coils underneath and make sure the fan is going / either of these could cause over run times ans tempt problems . if this does not correct problem then control has failed . . the dampner between freezer and frig is controled by the main control board .. mm
Posted on Oct 09, 2010
I have an Elite (106.5379202) and the damper and the return vent were both frozen. I removed the blockage, but after about 1 day the damper is frozen again. Did the BIT test and everything passed. What...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 19, 2011 | Kenmore Side by Side Refrigerator
2007 french door -bottom freezer -kenmore elite fridge- freezing foods in fridge and icemaker not making ice regularly- sporatically making small amounts of ice cubes motherboard was replaced when fridge...
Leo Ponder
imufo2
Sep 14, 2011 | Refrigerators
Kenmore Elite bottom freezer, model number 596.76522500, Serial Number 10310256GL. Water dispenser on the inside left of the refridge. Water dispenser is not working, items are frozen in refridge. Ice...
Leo Ponder
imufo2
Sep 09, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Hi my name is veronica my problem of my kenmore elite refrigertor is not cold enought...i want to know what is the tempertaure that need to be on
Problems with Temperature
If the refrigerator or freezer is not cooling properly, check temperature settings and air vents and ensure there is adequate room for proper airflow. Factory-recommended temperature settings are 0 degrees Fahrenheit (-18 degrees Celsius) for the refrigerator; and 37 degrees Fahrenheit (3 degrees Celsius) for the freezer.
If you need to adjust the temperature, do it one degree at a time and wait 24 hours before making additional adjustments. Check the air vents and make sure nothing is blocking them. Finally, if your refrigerator or freezer is too full, there will not be adequate room for air to circulate and cool properly. If these all check out, the problem could be with one or more compressor components and will require professional repair.
Have a nice day : )
Sep 05, 2011 | Refrigerators
The temperature of store room (not frozen) in my Kenmore Coldspot is always around 5 or higher degree, no matter where the slide bar is set to. But frozen room is work fine. What problem is it? How can...
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
My refrigerator temperatures suddenly changed from 40 degrees in the main compartment to 8 degrees and -30 in the freezer compartment. I'm unable to adjust the temperatures back to original settings. ...
Leo Ponder
imufo2
I have a Kenmore Elite Modle No. 795.7756200. M Havee it set at -1 in the frezzer and 38 in the refigurator. My proble is all the vegitables are frezzing in the vegitable drawer. I would appreciate any...
Leo Ponder
imufo2
Aug 25, 2011 | Refrigerators
I bought kenmore trio bottom freezer 2 years old, everything works fine, until one week ago, the fridge part becomes freezer, it frozen all the food, even I set temperature to 45F on the fridge.
Leo Ponder
imufo2
Aug 22, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
What makes a ref drops temp from 37 to 33 degrees
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Mar 20, 2011 | Kenmore Refrigerators
We just bought a Frigidaire Gallery Refrigerator and are not sure what temperatures to set the freezer and fridge to.
The freezer should be between -5 to +5 deg.F. The refrigerator should be from 33 to 40 deg. F. but it is really a matter of preference. I set mine around 5 and 33. I like to get my ice cream out and be able to scoop it and I like my milk very cold. Start with the manufacture suggested and then adjust from there with your own preference.
Dec 13, 2009 | Frigidaire Refrigerators
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
