Question about Smeg Dishwashers
I have a Smeg dishwasher SA660 EB. Still like new . Hardley used but have problems with the timer switch not progressing past 5 and also had the thermostat replaced as a loud bang heard and the machine did not work. Since warranty on repair run out it sounds like water is leaking around the thermostat through onto electrics as loud bang noise heard again . I found the thermostat just pushes up into the rubber seal in the bottom of the dishwasher. I have taken out the rubber seal as this also looked as if it was not water proof with the glue around it loose. Any ideas of a better seal system /thermostat . and how to place into 20 cent size hole in the bottom of the dishwasher. Thanks
  • 33 Answers
SOURCE: Westinghouse freestyle 920
was there damage to the door,when the door closes is it closing freely or is it hitting the cabinet on both sides it may need to be pulled out about 1/2 "
Posted on Dec 31, 2007
gamerfixer07
  • 344 Answers
SOURCE: Dishwasher tub leaks underneath
Hello. Anything is worth trying! But I would recommend epoxy. It works alot better with plastic and rubber items. Most of the leaks I have found in Kenmore machines are at the water pump. You may want to take a peek while it's running, just stay away from the wires!! Thanks!
Posted on Jan 18, 2009
localwonder
  • 6784 Answers
SOURCE: Kitchenaid dishwasher making funny noises while running
HI. this sounds like a busted impeller in the pump housing. there are two impellers. one for the wash and one for the drain. the drive shaft will strip the impeller center nut, causing this noise. I would inspect the pump housing for lose impeller action. replace the faulty impeller if found to be damaged.
Posted on Jun 11, 2009
SOURCE: dishwasher leaking around the bottom of the door
I had the same problem in 2004, lots of Bosch trained repair techs, calls to Bosch, and the appliance dealer we purchased it from with no answers. Our kitchen cabinet bases were ruined by the flooding that occured. After months of trying to get help I insisted on speaking to a supervisor that told me it was my fault for putting a flexible cutting board on the right side a blocking the vent. I told her that no where in the manual did it mention this issue and none of their trained techs were aware of this flaw in their design. When I asked about getting my cabinets repaired she said that was not an option. When I mentioned possible legal action her response was "good luck with that". Here it is 2009 and they recently called about a possible fire hazard recall for the control panel. The Bosch trained tech that came out to complete the repair knew nothing about the vent/flooding issue.
Posted on Aug 06, 2009
kirkx
  • 2019 Answers
SOURCE: Miele G646SC Plus dishwasher Drainage / inlet warning light
The main cause of problems like this that I have seen is where the sink drain is actually slightly clogged, and it is causing the diswasher water to back up, or for sink water to back up into the dishwasher. The drain line from the diswasher is supposed to run up as high as possible, or even go to an air-break valve, to reduce the problem.
Posted on Jan 21, 2010
Help! I have a Smeg oven Model Number: SA410X-5. All of the symbols have come off. I have just moved in to a new place with this oven and have no idea what the symbols are meant to be! Im urgent need of...
here is the manual
Smeg Multi Function Built In Oven Operation Manual
specs
Description
Smeg 60cm Stainless Steel Single Oven. Model: SA410X-5
  • RRP: $1,490. The RRP is supplied by the manufacturer and is based on a brand new item, not used. It is accurate as at 1st April 2010
  • Dimensions: 595mmh x 596mmw x 567mmd
  • Smeg thermosealed, fan forced, six function, 60 minute timer
  • Capacity 66.4 litre gross, 56.1 litre net
  • Installation underbench or wall (column), fascia: flush or proud mount
  • Thermostat variable 0 -250 Celsius
  • Multifunction five cooking functions plus defrost, timer 60 minute max, variable count down timer
  • Part number: 9842 (SN:SA410X-5) (145924-2)
Spares and schematic
SMEG SA410X 5 Parts List BigWarehouse Spares
New Fascia Stickers for 15.00GBP
Smeg SA410X facia stickers for worn fronts
Apr 03, 2018 | Smeg Ovens
Hi, my Smeg oven will not heat up. The light that normally comes on to show it is heating is not illuminated. In the past this has been because the clock/ timer has been switched off, but pressing these...
Disconnect the power plug and check using a multimeter on the continuity of the HEATINGS ELEMENT/COILS. If open then the coils must be changed. If not there is fault in the circuit. Check the panel control switches or the relay contacts when activated as this can be faulty., specially the feed from the timer panel.
Sep 19, 2011 | Smeg Ovens
The washing cycle does no proceed automatically however it does so when the dial is manually advanced. What could be the problem and how to sort it?
Sounds like the drive inside the timer switch. There is a timer motor that causes the timer switch to progress through the stages. When you manually progress the timer, it is physically turned to the next position and the switches all work as designed; it's just that the motor is incapable of doing that job for you as it should.
You need a new timer.
Mar 19, 2011 | Dishwashers
My smeg dishwasher seems to be permanently in wash mode. The light on the menu of settings no longer flashes, but permanently is on, and when I run a load it never stops. I hear the two beeps as if the...
You have a timer relay issue ,probable need a new board for it ,a cheap fix would be to time it and see how long it take to run full cycle and put a regulaer outlet timer on it or a alarm off your stove or what ever,save a couple of bucks
Feb 16, 2011 | Smeg STX2 Dishwashers
Smeg ST660 not starting
Switch the power off. Remove the 'built-in cupboard' panel from the front of the dishwasher and you should see the end of the timer spindle. With the power off you can turn this clockwise using another appliance knob or carefully with pliers. I think one 'start' position is with the flat section below the centre and horizontal. If the two lights are not on then try the 'start' button second from left to advance the timer.
Jan 13, 2010 | Smeg Dishwashers
Smeg integrated dishwasher continually washing - won't move to drying cycle.
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Nov 02, 2009 | Smeg STA4645U 18" Fully Integrated...
Dishwasher won't cycle through to rinse/dry/stop
Your timer switch is most likely defective.
It probably needs to be replaced.
It is like a clock with switches at different times
If it is stuck at a particular time it will run there forever.
Before servicing disconnect power!!!!!!!!!!
You can remove inside door panel with about 6 phillips screws or so.
Timer is directly attached to the dial on your machine.
These cost about $100.00 or less.
Can also be found used online for cheaper.
Oct 26, 2008 | Kenmore 24 in. 17512 Built-in Dishwasher
Smeg oven SA 392 EB - technical difficulties
first of all the yellow/orange light glowing is a known fault. it needs a slight wiring modification to fix it, however it dose not affect the operation of the oven nor is it dangerous.
now to the heating problem, there is a round element at the rear witch surrounds the fan. is this element getting hot? if not then it most likely needs replacing. it could be the thermostat but more likely the element.
Mar 05, 2008 | Ovens
Mid cycle stop
the thermostats need replacing thers 3 of them you can get to them from the front its better to take the door skin off first so you can see better then take the lower panel off.the thermostats are on the right hand side underneath.
Feb 12, 2008 | Asko D1716 Built-in Dishwasher
Smeg dishwasher
Hi, You can download SMEG dishwasher manuals from here: http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN Al.
Feb 02, 2007 | Smeg CSU2001 Built-in Dishwasher
Dishwashers Logo
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
