Question about Vizio L37 Television
Tv will not come on. on and off button does not work/
    Scholar:
  • 63 Answers
Buddy the main cause of this types of problem can be shot circuit. if it is so then you have to go for service.
If your tv is working but power button doesn't work then you can unscrew it and have a look. see whether button touch the sensor(it is in black color). it doesn't touch then you have to make it enable to touch by add some layer of paper or plastic,,(tips. don't ever use metal object). ; )
Posted on Oct 09, 2010
Need widescreen help for magnavox
unfortunately some of the controls do not work on the directv remote for your tv. You can reprogram the dtv to your tv using different codes or you can try the buttons on the tv. Look for the menu button and find out which up and down button and enter button works
Dec 03, 2017 | Magnavox 46MF401B LCD TV
Where is the power button of this aquos cardio vision tv? Is there any other way to turn on tv?The power button on remote can't work today.
First thing if there's a TV Button they pushing cause someone might of pushed the SAT or. DVD button. If that don't work check your battery's. some times I tap mine for hand hand lightly and then it works Good luck
Mar 19, 2013 | Televison & Video
How do i fix my broken power button on my samsung 40 lcd tv?
You can easially just replace the button assembly with included circuit board just unplug your old and plug in the replacement. They are very inexpensive and you can get them for most models at www.tvrepairworld.com
Jan 10, 2013 | Samsung LN-T4061F 40 in. LCD HDTV
My samsung remote for my blu ray player stopped working for my samsung TV today. i have never had this problem before. it still works on the blu ray player which then turns on the TV like it is supposed...
On blu ray remote control hold down TV Power+01 at the same time. If the TV turns off the controller is programmed. If not, try TV Power+02, +03, +04, +05, +06, +07, +08, +09. Different TV BRAND??? ...TRY http://remotes.com/remotes/documents/Samsung/AK59-00104K.pdf
Sep 16, 2010 | Samsung TV Remote Control
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Zenith remote will not work tv, need code
hello here is how you get your remote to work...make sure tv is on
step 1.hold down code search button till you see the red light
step2. let go of code search button and hit TV once light should blink
step3. press and release the power button while pointong a TV u ((may have to press the power button several times)) once the Tv powers off press the enter button once
step4. press tv button and hit power
May 16, 2009 | Zenith DBZN-311 Remote Control
Tv blinks out when front buttons are pushed. model#ws-65511
If the TV is turning on and working regularly, but power button does not shut down and buttons on TV do not work, then it is a faulty touch control (button) board on TV.
If instead the TV does not even turn on, then tv is on protection mode, in that case it can be any internal fault.
If instead the problem is with remote buttons, then it is either a faulty remote or a faulty IR sensor.
May 03, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
All buttons on tv stopped working only turns ON no ...
There is a button lock in the menu of the television. Using your remote access the menu screen and unlock the buttons.
Feb 19, 2009 | ViewSonic N3735W 37 in. LCD TV
CODE FOR TCL TV UNIVERSAL REMOTE CONTOL-CHUNGHOP RM -133E
If you don't have a code you can do these steps to get your universal remote working with pretty much any tv:
1.) Turn your TV on. Then on your remote press the set button, it's the small gray button above the green button that says TV.
2.) Press the TV button. There should be a red light to the right of the SET button. This means that your remote is ready for the TV code.
3.) To find the TV code, press the + or - on your remote. This is located above the orange buttons. Once the volume on your TV goes up or down, stop pressing the + or - button.
4.) Then press the SET button again to set that code for your TV.
If the above steps do not work, keep trying. It will work! ;)
Jan 30, 2008 | Televison & Video
Vizio L37 Television Logo
57 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
