Question about Panasonic DMR-E85H DVD Recorder
Power on, makes the LED goes off
My 18mth old dvd recorder (DMR-E85H) has suddenly decided to stop working. The power is connected to it and the fuse is ok. the screen is blank. If i unplug it overnight and plug it back in, the clock will display flashing, until I press the on button, then the whole thing just dies.
i also noticed last time I tried to play something that it reset itself and went into self check as it was spinning up the dvd. It also went into self check last time I tried to dub something.
Its no longer in warranty and I wondering what is causing it and is it worth fixing after I've seen so many other people having problems with this model?
any advice please ?
  • 185 Answers
Yes, it is definitely worth fixing!
The problem you will have is getting someone to do it for a reasonable price. I can tell you how to repair it but you will need to find someone who can use a soldering iron or have a go yourself. If you haven't used a soldering iron before, it's not a skill that can be picked up over night. A bit like riding a bike, it seems impossible until you can do it.
The fault has almost certainly been caused by a faulty component on the power board. It's an easy repair but you will need to dismantle the unit to get to the board. It's not difficult. You can get a new component online for a few pounds/dollars.
Nikko Electronics will supply the component or there are other suppliers.
I have given full instructions >HERE< to repair the DMR E55. The E85 is not exactly the same, but its very similar and it will be the same component.
Hope this helps
Posted on Jun 12, 2008
Why won't dmr e85h pick up all the digital channels the tv attached to it will? Is it outdated technology? Do you need a digital set top box or completely replace the unit? Anyone...?
You most likely will need a set top box connected to this recorder in order to receive digital channels, Assuming the DVD recorder works besides this detail, you should not need to replace the unit. Only replace it if it DOESN'T work.
The DMR-E85H is a 2005 model so it is more than 5 years old.
Mar 13, 2011 | Panasonic DMR-E85H DVD Recorder
Pan. dmr-e85h turned itself on, self-check
Open case and look for failed capacitors, which are cylindrical and will have a bulging top and a yellow/gold substance leaking out. If this is the problem, search for previous solutions that mention "solder capacitor C1260" for the DMR-E85. I had a similar 'no power' problem with my DMR-E55 and my son and I were able to fix it Sunday. Not hard to do and mine is working again!
Aug 05, 2009 | Panasonic DMR-E85H DVD Recorder
Panasonic dvd video recorder dmr-e85h is dead
I had same problem. I replaced two bad capacitors on the power supply card. See The capacitors I replaced were C1260 and C1261 slightly different from the one on "". Everything works now for me...
Good luck.
Also for those interested, I found the "commands" listed on useful when operating the DMR-e85h to correct problems.
Jul 26, 2009 | Panasonic DMR-E85H DVD Recorder
When I switch on the recorder goes into SELF Check for 10 to 20 minutes
Try replacing bad capacitors on the power supplycard. See
Good luck.
Alsofor those interested, I found the "commands" listed on useful when operating the DMR-e85h tocorrect problems.
Jul 24, 2009 | Panasonic DMR-E85H DVD Recorder
Panasonic DMRES30V DVD.
I have not but have decided not to try any more and will just buy another.
Thanking you.
Nov 24, 2008 | Panasonic DMR-E85H DVD Recorder
Faulty Panasonic DMR-E85H
My dvd DMR-E85H frequently displays self check, then goes blank
for long periods before eventually starting.
May 25, 2008 | Panasonic DMR-E85H DVD Recorder
You must replace the inside "str" sheet feeding and condenser close. Everything back to normal. :-)
Nov 25, 2007 | Panasonic DMR-E85H DVD Recorder
Dvd recorder loss of power
It could be a bad solder connection in the power supply that opens up after warming up (you may be able to tap on the unit to get it to come and go) or you could have a capacitor that is drifting out of tolerance or some semiconductor device that is becoming leaky. It may take a repair shop to figure it out for you.
Dec 29, 2006 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR-E85H DVD Recorder Logo
83 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
