Question about Sharp XE-A402 Electronic Cash Register
The paper does not want to go into the feeder. its not catching the teeth and its not feeding through
  • 360 Answers
Cut the end of piece and again reinstall it
Posted on Oct 13, 2010
Lexmark 4650 paper wont feed when printing. It starts the feed process but does not catch the paper. when it does it will take several sheets.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 20, 2011 | Lexmark X4650 InkJet Printer
When printing begins the paper feeds in diagonally and immediately crumples a bit and stops moving.
Take out the paper and look in the paper feeding slot: you will see a metal rod with seven rubber rollers on it. One of them (the one opposite the crumpling) is not catching the paper properly.
Easy to fix reasons are pieces of paper or debris caught in the plastic "teeth" of the mechanism, which stop the paper from being captured, and the whole rod snapped out of one side's retainers (gently pull it back in position until it clicks. The snapped-out side is the one opposite the crumpling).
The debris might also be just inside the feeder slot, so you'll have to use a strong light and hair-tweezers.
Unlikely-to-be-fixable reasons include worn out or defective rollers, severely snapped-out-of-alignment rollers and a warped rod.
You may get the printer to print (if the rod is intact but mysteriously not catching the paper) by keeping the paper upright with two fingers on the sides, so that one side's rollers only are supplying traction and your fingers supply the steadying. Not very satisfactory, but the "hand-feeding" often works.
You may also get some more weeks out of a worn roller by cleaning it carefully with a cotton swab and rubber cleaning fluid (beware not to use a solvent! "Rubber renewing" sprays are usually OK, just spray some on the swab). Sometimes, dust is enough to get an otherwise good roller out of operation; in this case the trick gets you a couple years' time.
Oct 22, 2009 | Canon PIXMA MX310 All-In-One Printer
Pper jams
The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
May 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Cannot load new paper roll into the calculator so it catches
Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
Then, slide the paper roll onto the feeder arm and you're in business.
Apr 09, 2009 | Sharp EL-1801C Calculator
Envelopes keep jamming
hello! try cleaning the paper feed roller where you feed the envelope in with denatured alcahol good luck
Dec 29, 2008 | Brother MFC-8460N All-In-One Printer
HL-207ON Brother Printer
Could not find that model????
I'm assuming you are talking about the fuser, where the paper exits? there are teeth or claws there that are supposed to help guide the paper out, when they get worn they catch the paper and make an accordion. depending on the model of the machine you will have to remove the fuser and take out the paper
Sep 29, 2008 | Office Equipment & Supplies
Feeder not catching on HP scanjet 7650
I had a similar problem where I had a jam, cleared it and it was not working again. It was a new machine within the store's warranty where I can return things no questions asked, so I returned it and got a new one. The new feeder won't catch at all and I never had any jams with the new unit - I put a stack of paper in to convert to PDF and it will do one at a time, or if it does do more than one, it misses stuff.
I never had a problem on the old machine until the jam. I don't know why the new one is not working.
May 09, 2008 | HP ScanJet 7650 Flatbed Scanner
Top Paper Feed Won't Work
Like a worn running shoes, the paper feed roller of the Automatic Document Feeder (ADF) have lost it's traction and has to be replaced or cleaned. Paper just slids and doesn't picked up properly without that little push. Professional servicers use a cleaner specifically designed for rubber rollers. However, YOU CAN get extra miles on it by dabbing a Q-tip in warm water and cleaning the paper feed roller on the ADF. Like all eletrical devices, the unit has to be turned off and unplugged before working on it. Take all precationary measures and goodluck.
Nov 29, 2007 | Brother MFC-3240C All-In-One InkJet...
Paper will not feed
Check for a jam again somewhere in printer unit, rollers, teeth, down back in paper feeder area. I thought i had no jam in my unit either until i got a torch and found the tiniest slip of a shred barely noticeable right in the middle of the teeth/roller. Remeber to turn it off after this, to reset it.
Aug 16, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Sharp XE-A402 Electronic Cash Register Logo
48 people viewed this question
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
