Question about Haier GDE700AW Electric Dryer
Dryer has no lights on the digital screen and the dryer will not come on or turn the drum
Check filter light flashing - dryer willnot start
Check the exhaust hose for crimping or blockage. Some models have a drum shaped inlet that slides over the fan housing inlet. A lot of times the lint literally piles up at the bottom in that inlet drum till it begins to restrict flow.
I changed the Drum belt on my Maytag this morning and, when I removed that part to get the belt around the drum, I was able to pull out a fist full of lint that had accumulated in that inlet drum that had to get by the lint screen first.
Dec 08, 2012 | LG DLE2532W Electric Dryer
My Maytag double stack gas dryer does not work, the screen is blank(not lighted)
Most clothes dryers have a thermal limiter or fuse, which is a heat-sensitive safety mechanism that shuts off heat to the drum or the power supply to the dryer if it overheats. Unfortunately, you can't replace a thermal limiter once it activates. The only choice you have is to replace it; your dryer won't operate properly until you do.
Although you can't reset a thermal limiter that has been blown, you can reset the dryer's two circuit breakers and restore heat to the drum and power to the dryer. However, after the breakers are reset, you'll still only have partial function of your dryer. For example, it might spin but not heat or it might initially turn on just to shut down after a few minutes. You must replace the defective thermal limiter to reinstate your dryer's full function.
Apr 16, 2012 | Dryers
Hello there, I have a Kenmore "Elite" Dryer, 592-895070. Less than a year old. My wife was drying some cloths and she noticed a couple of sticky stains on the stainless steel drum. I rolled the...
hello av that.... pull the top off and examine the belt that goes around the drum, also check the pulley. There you will find your problem. Joe
May 29, 2011 | Dryers
Dryer will not start but light comes on, heats drum okay. The dryer heats, the light goes off when the door closes, checked the drum and the belt is okay. When the start button is pushed nothing happens.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 30, 2010 | KitchenAid KEYS750LQ Electric Dryer
Won't spin or start
Sounds like the screen/sock combo got the tub in a bind and the drum belt broke.
If you want to pursue replacing the belt, let me know.
Apr 30, 2009 | Amana LGA10 Dryer
Dryer has power but drum want turn
check to make sure that nothing is stuck in the blower wheel if nothing is caught then you need a new motor
Dec 19, 2008 | LG DLE2532W Electric Dryer
Dryer isn't turning
This could be one or two things, it could be the safety switch located in door that activates the turning of the dryer. Or it could be a belt that turns the drum the motor could be turning inside and belt is broken.
Aug 16, 2007 | Kenmore Elite HE4 Electric Dryer
Haier GDE700AW Electric Dryer Logo
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Bill Long
Are you a Haier Dryer Expert? Answer questions, earn points and help others
