Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The chain will not slide on the bar after I tighten it. It initially flew off the bar, so I removed the cover, cleaned it and put it back together but I am having this problem. Thanks. George
    Problem Solver:
  • 19 Answers
When a chain comes off a bar during use, sometimes the chain will strike the bar and/or the chain guard (piece on the bottom of the saw where the chain goes back around the sprocket, that keeps the chain from hitting the user) and this will put burs on the drive links (parts of the chain that ride in the groove of the bar). These burs will cause the chain to grab onto the side rails of the bar when reinstalled onto the bar. The only way to correct this is to file the burs off of the drive links or replace the chain.
You can find flat files to file off the burs at your local hardware or building supply store and replacement saw chain loops at Partsbuggy.com.
Posted on Dec 14, 2010
How to take chain off poluan pro saw
Before putting your hands near saw chain cutters, put leather gloves on. Cutters sitting still can still draw some blood.
Loosen the nuts holding the clutch cover, loosen the adjuster, then remove the nuts. Remove the cover. Slide the bar along the studs, free of the adjuster, toward the clutch. Revove the chain from the bar groove, then move it clear of the clutch drive. It's now off. Good time to clean bar grooves and bar-mounting area of dirt & chips.
Reverse the procedure to install a chain, making sure the cutters have their cutting edge facing forward on the top of the bar. Make sure the adjuster is engaged with the bar before tightening the nuts at all.
Holding the bar nose up, tighten the adjuster until the chain touches the bar on the lower side. Tighten nuts.
After short run to clear any debris, recheck the chain tension.
Jan 29, 2014 | Poulan Pro Chain Saw 46cc 20"
How to put chain back on when it falls off
Almost every saw has a cover where the bar locks onto the saw, you take off the cover just as you do if you needed to remove the bar.
Just loosen the two or one bolts that hold the bar and slide the bar back, put on the chain and slide the bar back out.
Now there is suppose to be some play, the chain is not suppose to be very tight.
Here is what it suppose to be like.
Read this link that I post, it's easier to read this then me trying to explain it.
http://www.instructables.com/id/How-To-Tighten-a-Chainsaw-Chain/
Apr 14, 2013 | Poulan Pro 14" Gas Chainsaw 33CC P3314
How do you rePlace the chain on the 455 rancher?
You take the chain cover off of the bar. It is two nuts. Take them off and the cover will come off. Slide the bar toward you and the chain will become slack. You can then slide off the chain from the sprocket. To put a new one on. You will need to turn the chain adjustment back all the way to the left. Then put the chain back over the sprocket, then onto the bar. Put the chain cover back on and tighten the chain back up. Then tighten the two nuts back to tight.
Apr 03, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a 358351610 chain saw and need to find out how to remove the chain
Set the chain brake to off, then remove the fasteners on the right side cover where the chain drives from. This will release the bar which will slide back toward the engine and allow the chain to be removed. Note the direction of the cutting edge of the teeth. Clean everything including the two small oil passages that run from the large holes in the bar out to the chain groove on each edge of the bar. When refitting a new chain, back off on the chain adjustment screw (CCW) a few turns to allow the cover to fit to the bar properly. Fit the chain over the clutch sprocket, then insert the bar to the engine. Work the chain over the bar, then pull the bar outward to tighten the chain. Install the cover and the fasteners finger tight. Make sure the cover fits the bar properly. Tighten the chain adjuster CW so that the chain pulls up to the lower bar edge, but not so tight that you can't turn the chain by hand. Tighten the cover fasteners, then recheck the chain tension. The lower run of chain should be cutting as the chain moves toward the engine. Check the chain oiling by running the saw at speed with the bar tip near some cardboard--it should throw off a thin line of oil after several moments. Hope this helps!
Dec 19, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
How to put the chain back on a 14" Poulan electric chain saw
Remove the cover that cover the rear of the chain bar.Now,loosen the nuts that attach the bar and slide the bar reward.Now set the chain in the slotted part of the bar,pull it forward until there is abut 3/8 of an inch slack in the chain an tighten the nuts.Re-install the cover.
Sep 12, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Do not hive and need to know how to put new blades in. thank you ray
Almost all chain saw blade replacement is the same.
You remove the cover over the driving sprocket area.
You loosen two clamping bar nuts.
You loosen a small screw that helps tension the chain... this is usually parallel and close to the bar on the engine side of the bar.
You remove the old chain noting the direction of the teeth.
You put new chain on the same direction.
You partially tighten the bar nuts so they will allow bar to slide a bit.
You then tighten the tensioning screw until you can lift the chain halfway up the bar, away from the bar and have the guide that runs in the bar JUST come out of the bar at that point.
Fully tighten the bar nuts.
Replace the cover plate.
Put a little bar oil along the chain. Done!
Sep 11, 2010 | Garden
How to put chain on remington electric chainsaw
Remove the side cover over the chain drive area. Remove the bar and clean the entire mounting area. Run the saw for a few moments to assure that oil is oozing out of the side port where the bar mounts. Lay the chain out on a bench or table and inspect it for sideways bending, damaged or missing links/teeth, and deformed drive teeth. Inspect the drive sprocket for damage as well. Clean the oil passages in the bar end including the two channels that go out to the chain groove. If all looks well, place the bar back into position and push it back. Fit the chain over the sprocket, then work it over the bar and pull the bar out to tighten the chain. Fit the cleaned cover over the case and make sure the adjustment tang drops into one of the large holes in the bar end--you may have to back off the adjustment screw several turns first. Fit the cover and tighten the mounting hardware finger tight. Make sure the chain cuts toward you on the bottom run. Tighten the adjustment screw until the chain pulls up to the lower bar edge, but still allows the chain to be moved by hand. Tighten the cover hardware and recheck the chain tension. Run the tip of the bar near some cardboard for a few moments--it should throw off a thin line of oil on the cardboard. Make sure the chain is properly sharpened. Hope this helps!
Jun 20, 2010 | Remington Electric Chain Saw
Cover that holds downthe bar,over flywheel and tightens the
Remove the cover, bar and chain and clean averything. Check the brake band to make sure it isn't broken. Put everything back together and check again. It sounds like worse case it is a worn sprocket or bar.
May 16, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do i put a chain on the chainsaw
Set out the chainsaw parts in front of you. Make sure the chain is facing the right way to cut wood; the teeth should be facing away from you when you are holding the chainsaw.
Secure the chain around the sprocket (a cog-type part found near the chain tension nipple) and align it along the grooves of the bar. You will see a hole for the chain-tension nipple on the end of the bar. Line these up so the nipple fits in the hole on the bar. Pull the chain to tighten it, using the screw to achieve the desired tension
Place the cover plate back on top of the bar and line up the cover-plate housing screws with their corresponding screw holes
Screw the cover-plate housing screws back in and tighten. Test the chain to make sure it spins freely when pulled.
Check the chain to make sure you can lift it about 1/4 inch, so it isn't too tight to spin while cutting wood
Dec 21, 2009 | Televison & Video
POULAN CHAIN SAW MODEL 1420 ''Chain came off track
Chain is probably stretched. SAFETY FIRST. Electric saw, make sure power is unplugged. Gas saw, make sure sparkplug wire is removed. Remove the cover where the bar is attached to the saw. U should see an adjustment screw for chain tension and one or more bar lockdown screws. Loosen the lockdown screws and turn the tension adjustment screw to permit the bar to slide back toward the motor. Put the chain back in the bar track all the way around. Adjust the tension screw to tighten chain enough you can't pull it out of the track at any spot. Slide the chain by hand at least one complete revolution feeling for any rough spots. If it moves freely, turn the tension screw enough to tighten the chain properly. Correct tension should allow you to pull the chain appx. 1/16 to 1/8 inch from the bar. Tighten the lockdown screws, replace the cover. Rotate chain by hand a couple of revolutions again to check for smoothness again before starting the saw.
Jun 26, 2009 | Poulan 952801953 Electric Chain Saw
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
65 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
