Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My door only opens about 1 foot then it goes back to the close posistion. I opened the motor housing and the nylon screw in the middle to see contact with the sensors and the sonsor wont go at all to the open posistion it only moves about 1/4 of an inch and then closes again. I have a liftmaster
    President:
  • 3,197 Answers
Check your door springs. You may have a broken spring.
Posted on Oct 11, 2010
Craftsman Door Opener Model #139 53975SRT1 1/2 HP will not open the garage door. It will close it. And if it's on the way down and I hit enter, it will open mid stream. But, if it's closed, an
Two things. Check for a broken door spring. If okay, remove the cover from the motor housing and check for a bad drive gear. This is a white nylon gear just in front of the motor. If it is going bad it should be obvious.
Jul 05, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman 1/2 HP garage door opener, the left sensor is orange and the right sensor is green. the problem is that when i try to open the door, it only opens about a half foot and stays there. i...
Nothing wrong with the sensors and they only work when the door is closing anyway. Sounds like you may have a broken door spring or a bad drive gear. The drive gear is white nylon and is in front of the motor. It will be obvious if it is going bad.
Dec 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
The door latch on my 1999 pontiac grandprix was pushed in and now the door will not close. How do I get the latch to return its normal postion? The interior door handle and key button will not return it...
1) unlock the door
2) put a screw driver in the middle of were the striker goes and pull on the interior handle as you pull the screw driver out acting like its releasing from the striker. should work .
Oct 17, 2010 | 1999 Pontiac Grand Prix
Model # of my garage door 2280-267C serial #26142100151
Check your door springs to make sure one hasn't broken. Then remove the cover off the motor unit and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is going bad.
Jan 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door goes up part way and stops (about 2 feet). It does this most of the time but not all the time so we do not believe it is the sensor. It closes fine. To get it open we have to hit the button and help...
It is not the sensors. They only work when the door is closing. You need to check your door springs to make sure one isn't broken. Also remove the cover and check the drive gear. This is a white nylon gear just in front of the motor and it will be obvious if it is going bad. If both of these are okay you can adjust the 'up force' which is a control on the back of the motor unit near all those white wires. Increase this about 1/4 turn and try.
Nov 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Worked great the past 2 years. Now, garage door
Remove the cover and take a look at the drive gear. It is white nylon and is just in front of the motor. Most likely stripped.
Jul 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door goes up about a foot and stops
The sensors have nothing to do with your door opening. First thing to check are the door springs. One may be broken. Next remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It may be stripped.
Jun 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens about one foot and remains there.
Check the door springs. You could have a broken spring. Also remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It is possibly stripped. This is a good time to release the door from the opener and operate it by hand to see just how heavy it has become.
Jun 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears auto garage door opener not opening and closing properly
there are little knobs on the back for adjusting up and down turn them up and you should take care of your problem.
Feb 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door only opens 1 foot........
Most likely you have a broken door spring. Look closely as sometimes it is hard to tell. Also remove the cover and look at the drive gear. It is white nylon and is just in front of the motor.
Oct 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
175 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
