Question about Acer Aspire 5100 Notebook
Acer Aspire 5100 Display problem
I'm getting an intermittent screen problem. Occasionally the screen goes blue and gives the following message:
*** STOP: 0x000000c5 (0x00c50104, 0x00000002, 0x00000000, 0x00000000,
0x80ce7527)
It might be the graphics card? Or driver? Or RAM?
Any suggestions before I take it in for repair? Thanks
  • CeebeeMcM May 30, 2008
    thanks - but don't understand 'it could do rather driver' can you explain?
  • kubis May 11, 2010
    Hi, it could do rather driver. Otherwise if it would be some basic hardware it wouldn't pass the BIOS test (POST). If it normally works and suddenly blue sc., it could be that system tries to access to something what it can't get. It would be good to know during what event it does.
  • 8,596 Answers
Here's the collective wisdom so far: (reprint)
1) Blue Screen Stop Error. Acer freezes, flashes blue, and then restarts? www.microsoft.com. You can find a fix on Microsoft updates. This is a Blue-screen stop error. At the very bottom of the screen there shoud be the name of the file (process) along with the hex address of of the error., In my case it was related to the "ar5211,sys". Use the custom scan and it should show up under hardware.updates.; alternative - its a fault caused by memory but not because of memory.
Either check ur hard drive with a utility(chkdsk)
or remove hd and clean pins and connection(small shaving brush is ideal for this) replace hd.
It could be bad sectors on drive and if not solved sooner than later ur hd can become damaged beyond repair.
if you have a xp disk,boot up with disk and select "r" for repair then once in dos platform type in " chkdsk" this is the easiest way there are other ways but can cause problems.
(My Summary)
Chkdisk
Remove HD and clean pins
Boot up with OS boot-up disk and select R for Repair, then Chkdsk in DOS
Posted on Jun 10, 2008
    Champion:
  • 207 Answers
Its hdd back up the data it is goi9ng to crash wd in 3 mnts
Posted on May 30, 2008
My acer aspire 5517 laptop green blank screen and changes to red every 4 second!
More than likely the screen Inverter, Anowarul.
http://www.amazon.com/Acer-Aspire-Series-Inverter-Board/dp/B006BHRG9E
However the problem should be diagnosed.
Problem can be;
1) Graphics chipset
2) Video Cable
3) screen Inverter
4) LCD screen
I have a diagnostic flowchart you can follow, if you wish.
Post back in a Comment.
The plastic frame in front the LCD screen is the Display Bezel.
(Acer? LCD Bezel)
Once removed the screen Inverter is right there in front.
Mounted to the bottom of the LCD screen's Screen Frame.
Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to where it states - Aspire 1200 (1200 in Blue)
Drop down to the 7th line. (5310G)
Scroll across, and click on 5517.
http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Regards,
joecoolvette
Mar 19, 2013 | Acer Aspire Computers & Internet
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
Need SATA HDD password for acer aspire 5100
When everything gets done loading the screen says:
Unknown Disc
<There is no disk in this drive.>
it gives that error message 4 times on the "select partition" list
Reguardless of what i click (besides Quit) being Install or Delete, I get the Blue Screen of Death
"PAGE_FAULT_IN_NONPAGED_AREA"
Technical Information
STOP: 0x00000050
setupdd.sys Address F77F8245 base ar F77CA000
I did some research and I came up with possible RAM faultyness, so, I switched the RAM chips from my Acer to the AW (which obviously work, or else i wouldnt be typing this) and i get the identical blue screen error
What bugs me about that specific error is before it even says "Click button to boot from CD" it says RAM cleared... video shadowed etc. etc.
From beginning to end this is what i did:
1. Swapped out new HD
2. Used Utility disc to set-up HD
3. Attempted to install XP
4. swapped RAM chips
5. Attempted again
im at a complete stump to what to do to fix this... any help would be GREATLY appreciated
OR
http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Jan 20, 2010 | Acer Computers & Internet
After my Acer Aspire 5100 sleeps and the screen does not return
this is a problem with the standby feature there is a patch that Microsoft has put out that should fix the problem i think the main cause is having a usb device plugged in when going to sleep, search Microsoft knowldege base and it should pop right up
Jul 11, 2009 | Acer Aspire 5100 Notebook
Acer aspire 4520 -5458 gets a blue screen error message....
your harddrive has gotn fucked up or some thing try install ing and formating it from a cd if that doesent work order a nwe harddrive
Jan 02, 2009 | Acer Aspire 5100 Notebook
Blue flickering screen
What kind of motherboard/computer is it? Is the video onboard, PCI or AGP?
Aug 21, 2008 | Acer Aspire 5100 Notebook
Acer 5100
Are you able to restore the computer if so that may be your problem. By the way you have explained it seems like a software problem and not a hardware one.
Nov 19, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
284 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
