Question about Shuttle AN35N Motherboard
Looking for Manual for a shuttle AN35N Ultra v1.1 motherboard . Looking for power (wiring setup.
3 Suggested Answers
tseay11
  • 17 Answers
SOURCE: have athlong xp 2500, shuttle an35n ultra mother
I think that you might be asking about latency timings... Try downloading NVIDIA's Performance software. If you search google with those two words you will likely find it. When you install it, look for system settings and whatever you can change there, will be all that your MoBo allows you to change.
Posted on Oct 02, 2009
Awaji
  • 77 Answers
SOURCE: no power to motherboard Shuttle AN35n ultra
Hi there
Try One of the following steps:
  1. Flash Youre MB BIOS.
  2. make sure that CPU Fan is working OK.
  3. Is the CPU attached to the MB correctlly.
  4. Is the CPU Fan base and scrowse faremly scrowd and positioned on the MB.
  5. Chec MB in/pot power pins connections.
Hope That will Help.
Posted on May 16, 2009
Where i can download drivers for AN35n ULTRA V1.1 (free) help!
Go thru below Link.
http://www.shuttle.eu/_archive/older/en/an35n_faq.htm#download
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
May 27, 2011 | Shuttle AN35N Motherboard
My AN35N Ultra v1.1 begins to boot then auto-shuts down. A red light "D30" eluminates and all aux powered systems power down. What does D30 red light mean?
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 18, 2011 | Shuttle AN35N Motherboard
I have a an35n ultra v1.1 motherboard I power on my tower,it does power on but it wont post I dont see anything wrong with cap's cpu was tested and checks out Power supply is good Tryed a new video card...
Hello Phenom, Hi.... to properly run/test a motherboard, you need to make sure this parts are good with no doubt functioning. 1. the power supply, 2. Memory, 3. keyboard, 4. Processor with FAN 5. PC speaker(built on-board or the thumb speaker) and 6. monitor How to test. First remove all motherboard connections. Now reconnect the following. 1. make sure that the power supply 20/24 pin is connected properly to the motherboard (and please test this power supply before making connections. To test independently short green wire to ground and plug the unit. you should see the fan spin) 2. make sure that the 4 pin 12volt power connector is also plug in nice and tight. 3. clean the memory slot using a clean paint brush and the module (DDR/2) terminals (the contacts) using an eraser, 4. connect the keyboard, 5. make sure there is a PC speaker connected. 6. connect the power switch of the front panel, 7. Connect a monitor on the VGA port 8. Power on the PC. 8. Look at the keyboard lights 3 LED momentarily. num lock + caps lock + scroll lock and after several seconds 1 LED light, num lock only. If you reach this part you should also hear a beep. then the POST will appear. If you don't reach this part, start again from the top. do this several times. Still no response? you motherboard is bad.
Jan 07, 2011 | Shuttle AN35N Motherboard
Wont start after disasemble and cleaning. just redlights and i think my wires are wrong cause i forgot how it goes.
Which wires do you mean? The wires for the reset and power buttons on the case? The pin arrangement is usually part of something called the front panel header, it's a series of pins for stuff like the power LED, HDD led, and speaker. The pin arrangement should be in your motherboard manual. If that's not what you're talking about please clarify. If you're in the Washington DC/Rockville MD area, please shoot me a line at Inovagent.
Nov 03, 2009 | Shuttle AN35N Motherboard
Have athlong xp 2500, shuttle an35n ultra mother
Oct 02, 2009 | Shuttle AN35N Motherboard
My Bios not run more. My AN35N ultra is dead
find someone who has a computer that you can get on line with.
youll need a floopy drive on both your computer and the one your using, go to the manufactures support website and download the bios file for your motherboard to the floopy. then take the floopy and put it in your computer and start it up. it should download the bios to your system.
if you dont have floopy drives, you can use a usb drive if your systems are set up for usb, but your boot order also have to be setup to recognize the usb.
if this is an older computer you most likely have a floopy drive.
hope this fixes your problem.
would appreciate your leaving feedback for me
thanks.
May 17, 2009 | Shuttle AN35N Motherboard
No power to motherboard Shuttle AN35n ultra
Hi there
May 16, 2009 | Shuttle AN35N Motherboard
AN35N Ultra MoBo doesn't boot.
hi,
First  u check the k/b numlock status  if it is glow (on/off ) while pressing numlock, motherboard giving display but  ur display adaptor giving problem.
Change the vga adaptor and  try it
Thanks
Was this soultion helpful ? show ur appericiation for it
Mar 21, 2008 | Shuttle AN35N Motherboard
Just Bought The Mach 4 tried to test it with current power supply
Hi, one quick thing you can check is to see if the cable running from the power switch is plugged onto the right pins on the motherboard, it will most likerly say (pwr btn) next to the pins or something like that, it may also need to be a certain way round.Let me know what the outcome is if no good we can try something else. hope this has helped. Thanks
Onlinepc-Fix
lee
Mar 18, 2008 | Pine Technology Mach 4 KT400ANB...
AN35N Ultra not wanting to boot past BOIS screen
remove your power socket from motherboard and short the pin green and black if the smps is working the problem is with power supply in your motherboard
Dec 08, 2007 | Shuttle AN35N Motherboard
Shuttle AN35N Motherboard Logo
1,152 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
