Question about Philips Televison & Video
40PFL3705D/F7 TV has about 1/2 second lag when using video game console (ie xbox). Tried turning off 120hz refresh but no difference. Am not even sure disable of 120hz was successful since picture did not change. How do I get rid of the lag?
2 Suggested Answers
  • 360 Answers
SOURCE: TV Manual for "40" PHILIPS
Paste the following link in your browser & download the manual.
http://download.p4c.philips.com/files/4/40pfl3705d_f7/40pfl3705d_f7_dfu_aen.pdf
sonsunny
Posted on Jul 05, 2011
sonsunny
Jul 04, 2011 | Televison & Video
Just got an xbox 360 slim 250GB but when I went to play halo 3, the game was lagging along with the xbox menu itself. I even connected a plug-in controller and I had the same result showing that it was not...
If you just bought it brand new, then return it for an exchange. Its not wise to keep an electronics appliance or game console that is having issues straight out of the box. Using your A\V (RCA) cables instead of an HDMI cable shouldn't be causing any lag, at least nothing that is significant enough to notice.
Aug 17, 2010 | Microsoft Xbox 360 Console
Just purchased a Insignia TV and hooked up our Wii, now we are having lagging issues. Anything we can do?
This answer only pertains to the Insignia Advanced TVs:
There is a game mode on this TV that will increase the response time for you, but you can also turn off ABL, 120Hz, and any other video enhancements that cause lag.
The GAME MODE button is on the remote and on the side of the TV. They should work the same, but if not there is a problem with the remote code.
Also, check to see if there's a firmware update for the TV on www.insigniaproducts.com
I hope this helps.
Feb 22, 2010 | Nintendo Wii Console
Insignia lag with X Box
Turn game mode on and put your xbox in hdmi 3 and if that doesnt work go to picture settings then advanced setting and turn dcm off
Feb 21, 2010 | Insignia 42" LCD Flat-Panel HDTV
XBOX 360 lag with Insignia TV
i had the same problem. go on your tv to advance video settings and turn DCM to off. solved the problem for me.
Feb 09, 2010 | Insignia 42" LCD Flat-Panel HDTV
I hear sound on my TV but the screen isnt showing anything i trued to different cables and it still doesnt work...i even tried hooking it up to the TV but nothing
Try overheating the xbox-->Put some towels around it and leave it on for 30 seconds.turn it off and turn it back on again.It works for lots of people :)
Jul 25, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 keeps blacking the screen out for about 1 to 2 seconds at seemingly random intervals. The game continues progression as normal underneath but I have experienced some lag issues, specifically with...
Hi, your X-BOX is overheating. this will continue to progress. Read the following details below to combat this issue before it ruins the gpu.
Alternativly Overheating can be cause by the console locking up or "freezing" after a set amount of time. Lockups that occur at a specific point in a game are generally problems with the game itself and not caused by overheating.
THINGS TO TRY
  1. Let the Xbox 360 console cool.
    Note You may have to wait several hours for the console to cool enough. Do not turn on the console when the console is hot.
  2. Verify that the console has sufficient ventilation and that the fan is operating. For more information about ventilation, see the "More Information" section.
PREVENTION SUGGESTIONS
To try to prevent this problem, use the following precautions:
  • Do not block any ventilation openings on the Xbox 360 console.
  • Do not put the Xbox 360 console on a bed, on a sofa, or on any other soft surface that may block ventilation openings.
  • Do not put the Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well-ventilated.
  • Do not put the Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
DO NOT EVER PUT YOUR CONSOLE IN THE FREEZER OR OUT IN COLD WEATHER
Some people think that doing this might help "fix" an overheating console, in fact doing so could cause even bigger problems. Electronic devices like your console are made to function at and around room temperature, extreme cold temperatures can often cause just as many problems as extreme warm temperatures (such as overheating). Also if the console is located in a dramatically cold area while running, the difference in temperature between the hot console and cold air can create condensation which in turn will short out your console making the situation far worse. Condensation will happen more quickly if your console is overheating due to the greater difference in temperature. In short... DON'T DO IT.
A more aggressive Solution to overheating is to improve the cooling system of the console. The best solution is to replace the thermal compound. If you attempt this you do so at your own risk. If you're console is still under warranty it is recommended that you contact MS for a replacement before attempting to fix it yourself.
Jun 09, 2009 | Microsoft XBOX 360 ARCADE Console
Unknown problem in my xbox 360
3 likely possibilities -:
1) The slide switch on the Video Lead plug (plugs into Xbox) is in the wrong place for where its attached to you tv.
2) you consul is set to PAL not NSTC or the other way around.
3) Wrong video refresh rate, should be 50 for PAL Uk 60 NSTC
Feb 12, 2009 | Microsoft Xbox 360 Console
XBOX 360 COLOR KEEPS GOING ON AND OFF
You can send your broken xbox 360 to my shop Fixit repair service and I can send you a refurbished xbox 360 system for $80 and one year warranty here is the number 206-271-0529
Nov 07, 2008 | Microsoft Xbox 360 Console
Xbox 360
Things to try -
1. Try using a different video port on the TV.
2. Try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
Feb 17, 2008 | Microsoft Xbox 360 Console
Televison & Video Logo
228 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
