Question about Kenmore Dryers
Kenmore gas dryer model 110.97580110 it is not drying
  • 94 Answers
SOURCE: kenmore gas dryer
That model does not have a pilot light.  It has an electronic ignitor.  If it is not igniting, either the igniter is not getting a signal to ignite, the igniter is burned out, or the gas solenoid is broken.  Probably the igniter is burned out.  It is item number 3018 at RepairClinic.com.
Posted on Oct 21, 2007
SOURCE: No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Posted on Nov 11, 2008
danromarris
  • 101 Answers
SOURCE: dryer won't heat up
It could be the problem, you are definitely on the right track. There are a lot of things though that could cause a dryer to not heat. I try to give the most common reasons as it is hard to determine without hooking up a voltage meter to the parts. One thing is that your vents may be clogged up somewhere between the dryer and the outside. A lot of people don't want to believe that the problem is that, but it is common and if that is the problem better to be that then something wrong with the dryer. Anyway, check outside where the vent is and feel if the air coming out is strong. If it's not that may be the issue.
Next, if the air is good, open up the bottom panel so you can watch the dryer working. Watch and see if the ignitor is coming on. You may just have a problem with the thermostat which tells the dryer when to shut off the heat when the temp in the drum has reached the max. It should go up to about 110 degrees and then turn off, when it gets down to about 70 or so it will come back on. That is the job of the thermostat, to regulate the temp. If it does not work though it just won't heat.
If your ignitor does come on and you see the flame and it goes right off then you need to replace the thermostat. If it doesn't come on at all though you will need a new ignitor seloniod. Let me know if you have any other questions and let me know if this was helpful for you. It might be wise to have a tech come out and fix it too as some of those things can become quite a pain to fix. Gas dryers are a lot more complicated then electric. Good luck and glad to help.
Posted on Jan 22, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Kenmore gas dryer not getting hot enough
Have you checked the lint trap and also the vent hose? If you have yet to do that try it. Also make sure that the vent line is not crushed. It needs to be wide open
Posted on Feb 10, 2009
jumptrout51
  • 3361 Answers
SOURCE: kenmore gas dryer model 97284100
The door latch is about $5. Replace it.
Any appliance parts store has them.
Posted on Mar 27, 2009
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
We have a sears dry model no. 1107481220 and the dryer is not drying the clothes.
Ok, first does the heat come on at all, if not,, make sure the gas if coming on, if it is, you need to check the thermostats, If its not, you need to replace the coils located on the gas valve itself it looks like this http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Dryer-Parts/694540/0026/110/Model-11074812200/0582/0151200?keySuffixId=NA&productTypeId=x&searchModelNumber=11074812200&subCompDesc=Burner%20assembly&brandDesc=KENMORE&modelDesc=GAS-DRYER&blt=11 that is the main one, and you have a second one too that should be replaced at the same time, it has 3 terminals, for a diagram of the burner assembly click on this http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11074812200/0582/0151200?searchedModel=1107481220&blt=
Jul 09, 2011 | Kenmore 74892 Gas Dryer
Kenmore dryer thats not drying
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 01, 2010 | Dryers
10 year old kenmore model 110 gas dryer drum turns but will not dry clothes
I have a Kenmore Model 110.74612200 it came with the house and needs another service call-not heating- how old is this model? Wondering if it might be time to buy a new one. Dryer has seen a lot of use in the past 5 years from a household of six.
Feb 21, 2010 | Kenmore 63942 Dryer
Gas Dryer drying clothes cold, no heat...
if it heats for a while and then no heat you have bad gas coils,when the coils are on there way out they work until they heat up then they cut out,see if you have heat when the dryer is cold,if it is change out the gas coils
Jan 25, 2010 | Kenmore 63942 Dryer
Gas dryer starts to tumble but it doesn't get hot and dry clothes
It's either a ignitor or the gas valve. Is this something that you could work on?
Sep 02, 2009 | Kenmore 63942 Dryer
Kenmore Model 110.747424000
check your exaust blower wheel...its defective
Dec 12, 2008 | Kenmore 72802 Gas Dryer
Nov 02, 2008 | Kenmore 73952 Gas Dryer
Kenmore dryer only heats on delicate
how to install rubber belt on kenmore gas dryer number 110.72712101 ?
Jun 14, 2008 | Kenmore Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
